Radiator Fan Relocation (pics)
Old Nov 26, 2002 | 08:05 PM
  #26
Danger's Avatar
Default Re: Radiator Fan Relocation (FredoSP)
just wat i was looking for . thanks .
Old Nov 26, 2002 | 09:01 PM
  #27
a z n t a k's Avatar
Default Re: Radiator Fan Relocation (jonny5)
nice set up! good job!
Old Nov 26, 2002 | 09:04 PM
  #28
philo's Avatar
Default Re: Radiator Fan Relocation (SO3Burner)
you can use two 12" fans on the GSR radiator, ithats pretty common.
Old Nov 26, 2002 | 09:05 PM
  #29
philo's Avatar
Default Re: Radiator Fan Relocation (blu_si)
not sure exactly what you mean, IM for questions on the SBC-ID.
Old Nov 26, 2002 | 09:42 PM
  #30
EU BATT's Avatar
Default Re: Radiator Fan Relocation (philo)
I have the dual fal fans on my integra now and the max rev mani makes my turbo rub it now. Anyone have any ideas of what to do?
Old Nov 26, 2002 | 09:49 PM
  #31
philo's Avatar
Default Re: Radiator Fan Relocation (EU BATT)
If you already have the pushers fans and still need more space I have seen the radiator moved in front of the cross member. May be hard to do with A/C though.
Old Nov 26, 2002 | 09:50 PM
  #32
V-SPEC 1's Avatar
looks good!
Old Nov 26, 2002 | 09:53 PM
  #33
1.8T_EG's Avatar
Default Re: Radiator Fan Relocation (boostedb20vtec)
Old Dec 13, 2002 | 10:21 AM
  #34
cinq's Avatar
I like what you did with the intercooler...very stealthy.
Old Dec 13, 2002 | 10:37 AM
  #35
PM-Performance's Avatar
Default Re: Radiator Fan Relocation (cinq)
well with my stock fans my intake side wont even fit with the fans in and the ehaust side it just tuches the fans .
i was just gonna notch the fans a little, but maybe ill try this set up to se if it works better in my set up . . . . very nice work
did you still sue the plugs from the stock fans ? or did you have to do a splice job to reverser the polarity?
Old Dec 13, 2002 | 10:45 AM
  #36
Jason kiDD's Avatar
Default Re: Radiator Fan Relocation (itr206)
Quick question. Did you still use the fan switch of the stock fan or did you run it straight into the harness.??
Old Dec 13, 2002 | 11:00 AM
  #37
98Psi ITR's Avatar
Default Re: Radiator Fan Relocation (Jason kiDD)
Looks good, time for a larger D intake pipe.
Old Dec 15, 2002 | 10:20 AM
  #38
EG6owner-T's Avatar
Default Re: Radiator Fan Relocation (98Psi ITR)
Old Dec 15, 2002 | 12:55 PM
  #39
APEX i GSR's Avatar
looks very very nice
Old Dec 15, 2002 | 05:28 PM
  #40
turbologist's Avatar
How is the paint holding up on the i/c?? Dont flame me but can u just flip ur regular fan around and reverse polarity, or would u have to buy a specific puller fan?
Old Dec 15, 2002 | 08:12 PM
  #41
philo's Avatar
Default Re: Radiator Fan Relocation (Turbologist)
The blades of the fan are designed to push air in one direction, you can only change a fan from puller to pusher if the blades can be removed and flipped. You can do this with universal fans but not OEM fans.
Old Dec 15, 2002 | 08:26 PM
  #42
zojirushi's Avatar
dammit, can't wait till i get my pusher fans... can finally put a damn filter on my turbo. And get my damn a/c fixed !
Old Dec 16, 2002 | 08:51 AM
  #43
EU BATT's Avatar
I'm not too sure about that, because on a regular ceiling fan, if you want the fan to push air up or down it just depends on the direction the fans flow. Just my .02.
Old Dec 16, 2002 | 08:27 PM
  #44
philo's Avatar
Ceiling fan??? The blades on a radiator fan are curved, you could run them in reverse but they would not work very well. The OEM fans also have a cowl that would block the flow of air whilst cruising. Either way its a bad idea.
Old Dec 17, 2002 | 04:51 AM
  #45
EU BATT's Avatar
O ok, just wanted to clear that up! Thanks!
Old Jan 10, 2003 | 01:59 PM
  #46
redline201's Avatar
i have a 95 civic cx with a b16a and a del slow radiator
i have the max rev kit going in soon
will those fans fit my hybrid
also i have ac (not in the car right now buts its going put back in asap )
thanks guys
[Modified by redline201, 6:00 PM 1/10/2003]
Old Jan 10, 2003 | 02:52 PM
  #47
civbeater90's Avatar
Default Re: Radiator Fan Relocation (redline201)
how thick are those fans?
Old Jan 10, 2003 | 05:30 PM
  #48
ASHY-ELBOW's Avatar
Default Re: Radiator Fan Relocation (civbeater90)
yeah i have an AC question too....on a gsr if you are gonna keep your AC would it be better to have one in front of the radiator on teh drivers side for the ac and the other on the passenger side behind the radiator on the engine side? or would it work just as good with both up front like his are in the pic?
[Modified by 1320racing, 2:30 AM 1/11/2003]
Old Jan 10, 2003 | 05:51 PM
  #49
SIXTYdashONE's Avatar
HT's Biggest Loser
heres a pic of mine....yay
Old Jan 11, 2003 | 01:13 PM
  #50
Evil EG's Avatar
Default Re: Radiator Fan Relocation (SIXTYdashONE)
I just picked up a pusher fan but im looking on my teg and I dont think one can fit on outside of the radiator. It will hit the ac condenser.
