quidence on a 12 second run
Old Jun 2, 2002 | 07:51 AM
92JDMSiR's Avatar
Default quidence on a 12 second run
I posted yesterday about my run of 13.6 @106 on a drag equipped b16 hb. this was at 5 psi on michelin XGT V4's. what can I do to run high 12's? is it ok to turn the boost up to 7 with stock injectors? Iw as thinking of just turning the boost up to 7 and running slicks.
OH YEAH, what is an ideal size slick for my kind of power level. b16, drag 3. thats it at this moment.
Old Jun 2, 2002 | 10:27 AM
DLB1994's Avatar
Default Re: quidence on a 12 second run (92JDMSiR)
13-8-22M/T and u can run 7psi on stock injectors
Old Jun 2, 2002 | 11:03 AM
PrecisionH23a's Avatar
you are running a fmu, an inline fuel pump right, and intercooler, right? you should boost 7psi with no problems. if you wanna hit high 12s, get some micky t's and gut the **** out of your car. what 60ft times are you cutting?
[Modified by GudeH23a, 3:03 PM 6/2/2002]
Old Jun 2, 2002 | 02:05 PM
92JDMSiR's Avatar
Default Re: quidence on a 12 second run (GudeH23a)
the car is gutted and my 60 ft sucks ***. 2.25 was the best. I need help in the traction department.
Old Jun 2, 2002 | 02:16 PM
get some micky t's, they help out tremendously. running 12's from your 13.8 is gonna be tricky.... if you do make sure and post
[Modified by GudeH23a, 6:17 PM 6/2/2002]
Old Jun 2, 2002 | 03:07 PM
DLB1994's Avatar
with 106mph u can run 12's with your same setup just get some of them 1.7 60foots times
TeknikDC2
May 5, 2005 09:04 AM
EG-6Ghost
Jun 23, 2004 08:10 PM
DOHCarp
Jul 7, 2003 03:30 PM
2ltrsnailpwr
Jun 24, 2003 06:55 PM
HotRodTeg
Nov 14, 2002 06:20 PM
