Quick wastegate question..
Old Aug 28, 2013 | 09:25 AM
Builda'Teg_92's Avatar
Default Quick wastegate question..
I have quite a few parts let over from a previous build and I wanna incorporate them into my newly acquired type-s. One of those parts being a Tial 38mm 2 bolt WG. Seems like all the sidewinder manifolds I see have a v-band for the 44mm MVS gates. I found an adapter that lets you turn your 38mm 2 bolt flange into a 44mm v-band, but not sure if that will work the other way around.
I was thinking turn it around and use the V-band side of the flange to connect to the manifold and the 38mm 2 bolt side to the wastegate I have now. Hopefully that makes sense?
Also, because Im already here ill ask. I cant seem to find charge pipes for an RSX, on the full-race website the closest I can find are these: http://www.full-race.com/store/charg...0mm-q-bov.html
Obviously that's not an RSX but im still wondering if they will fit. Thanks
Old Aug 28, 2013 | 09:27 AM
Default Re: Quick wastegate question..
Adapter on the right^
Old Aug 28, 2013 | 09:45 AM
kyden's Avatar
you can use it, but you're gonna run into a ton of boost creep issues with a 38mm wastegate.
Old Aug 28, 2013 | 12:01 PM
ballistic1350's Avatar
unless of course he runs alot of boost...
Old Aug 28, 2013 | 03:30 PM
I wont be, maybe 13-14lb's on my little garrett 57. Daily driver, Guess ill try to get as much as I can for this one and upgrade. Its just the fact that it was brand new Thanks
almostjdmeg
Feb 9, 2010 07:17 AM
Turbocivic94
Welding / Fabrication
May 22, 2009 04:56 PM
Cloneufc
Feb 9, 2008 07:36 AM
J337_UNIT
Feb 17, 2004 09:41 PM
redboost10
Nov 12, 2003 03:58 PM
