quick turbo part question
Old May 1, 2011 | 06:01 PM
EGcivic_95's Avatar
Default quick turbo part question
okay guys i have a little issue going on, well my turbo oil feed line adapter piece that takes to bolts to mount on the turbo well mine stripped. is there another way i can get this problem fixed with out ordereing the entire oil line kits?
Old May 1, 2011 | 06:38 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: quick turbo part question
english > you
drill it out one size bigger and re-tap it or heli-coil it
Old May 1, 2011 | 06:49 PM
EGcivic_95's Avatar
i ment the piece that bolts to the trubo its self not the line, the aluminum piece
Old May 2, 2011 | 03:31 AM
Turbo-LS's Avatar
Yeah go online ebay or google and order the one piece you need. just be sure you get the proper size to match the feed line fitting
Old May 2, 2011 | 04:09 AM
wantboost's Avatar
Who is Mr Robot?
thats what i meant...
Old May 2, 2011 | 07:46 AM
turbohatch96y7's Avatar
I think what hes saying is that the threads are stripped on the turbo drain bolts.. Im guessing he over tightened the boltd and backed em out
Old May 2, 2011 | 09:11 AM
EGcivic_95's Avatar
no its on the oil feed line. the aluminum piece that mounts on the turbo its self. the threaded nipple that the line hooks to is stripped. it was loose so i tightened it and it just would not tighten up so i backed it off and its stripped
Old May 2, 2011 | 12:03 PM
siblues's Avatar
Yes you can buy just that piece its like 15 bucks on ebay.You can call Stan at Fast-Turbo too he has them in stock and will get it to you fast and cheap.
Old May 2, 2011 | 04:39 PM
evrythng_fast's Avatar
too anyone can you run a open wastegate? im just wondering im turboing my 92 integra da and need to know..
Old May 2, 2011 | 11:44 PM
siblues's Avatar
How do you plan on controlling boost?
Old May 3, 2011 | 02:20 PM
EGcivic_95's Avatar
ok well i got back from the tuner had a few issue are occurring so i need some help on pin pointing these reasons. the first one is we could not get the 2nd spark plug out it was stuck in there and i didnt want to break it off. 2nd im having a weird noise coming from the turbo area, when i shift i dont hear my blow off valve any more all i hear is a short burst of air or a screatching as boost builds or randomly in a gear and i have little to no power since this has happened. any ideas will be deeply appreciated.
Old May 3, 2011 | 02:59 PM
EGcivic_95's Avatar
okay well i tried to pin point the noise and i dont think its coming from the turbo or wastgate its a loud ching or a weird scretch coming from either the back of the motor or the intake area, but it haappens when i rev it up and it does it once ever rev so it cant be a rod any ideas?
Old May 3, 2011 | 06:08 PM
EGcivic_95's Avatar
ok its from the front lol was hard pin pointing it but any ideas? i can try putting a sound clip on
Boostinb20!
Mar 27, 2009 07:06 AM
BigZeke5
Oct 16, 2008 06:20 AM
daluv
Jul 31, 2008 12:20 PM
Del$olB16A3
May 31, 2005 04:16 PM
dturbo
Feb 10, 2005 08:15 PM
