Quick ?, TB vacuum line
Old Jun 10, 2006 | 09:59 PM
Nisif's Avatar
Default Quick ?, TB vacuum line
Unfortunately I don't have a digi cam or else there would be pics to clarify. I have a 92 ls motor and on the throttle body (above the mechanism that rotates and the tb cable slides through) there is a piece that connects to the tb, and it sits higher than the tb. This piece is circular and has a flat spot which is the size and shape of a silver dollar. There is a vacuum line that runs off of it to the oem intake arm from the factory. My intake charge pipe doesn't have a fitting for it. Is it neccesary to run this line or should I plug it at the tb? Btw, I'm not referring to the vacuum line that routes to the evap canister. I sifted through the ls turbo thread but it appears that the newer ls motors don't have this piece attached to the tb.
Old Jun 14, 2006 | 04:42 PM
Nisif's Avatar
Default Re: Quick ?, TB vacuum line (Nisif)
Here's a pic of what I'm talking about:
Should I tap the intake piping for the vacuum line or just plug it?
Modified by Nisif at 5:01 AM 6/15/2006
Old Jun 14, 2006 | 04:51 PM
Turbocivic94's Avatar
I always take them off
Old Jun 14, 2006 | 06:00 PM
Nisif's Avatar
Default Re: Quick ?, TB vacuum line (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">I always take them off</TD></TR></TABLE>
Okay, so should I plug the fitting, or leave it unplugged with the vacuum line unhooked?
Old Jun 15, 2006 | 10:52 AM
Take the valve off your intake manifold completely
omgwtfbbq
Mar 6, 2009 09:13 PM
4dooritr
Nov 8, 2007 09:23 PM
aaj23
Jul 17, 2003 10:11 AM
