Quick questions about my Tial 38mm wastegate.
Sorry for the post, I'd get in my garage and see for myself but it's dark as hell and my light broke.
Anyway, I got my 38mm Tial today and was wondering a couple of things about it.
Anyone know where to get a 90 degree elbow? Of course, with my god awful 88-91 chassis, it hits the hood
What are the top and size nipples used for? I was told I can plug the top with a screw and connect the side to my MBC. I thought the side nipple was for a pre throttle body vacuum source and top goes to the boost controller. Is this right?
Thanks
EDIT: Made it shorter. Ben answered some questions
Modified by Hoosier Daddy at 9:45 PM 4/28/2004
Thanks
Re: Quick questions about my Tial 38mm wastegate. (Hoosier Daddy)
The supplied bolts are used to bolt the WG to the manifold. The metal rings goes between the WG and manifold (fat side down).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hoosier Daddy »</TD></TR><TR><TD CLASS="quote">
Anyone know where to get a 90 degree elbow? Of course, with my god awful 88-91 chassis, it hits the hood </TD></TR></TABLE>
We carry the elbows but are out of stock. More coming in on Monday.
Thanks
The top port you leave open unless running a boost controller. Do NOT plug it up. The side port goes to a vacuum source, either from the intake manifold or the turbo compressor. Hope that helps.
Thanks
Re: Quick questions about my Tial 38mm wastegate. (ben@importparts.com)
PM'd you about the elbow. I'm gonna be using a boost controller so I guess I need the nipple, which means it won't clear Thanks for the help
My dsm friend runs the same exact wastegate but his top nipple is left open. He runs his mbc to the bottom nipple and holds steady 20psi, this shoudl work on hoosier daddys setup correcT?
Re: (Phaze2 Mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phaze2 Mike »</TD></TR><TR><TD CLASS="quote">My dsm friend runs the same exact wastegate but his top nipple is left open. He runs his mbc to the bottom nipple and holds steady 20psi, this shoudl work on hoosier daddys setup correcT?</TD></TR></TABLE>
