Quick question on Walbro Pump part #?
gss342 is high pressure 255lph which can go past 90psi and still flow decent amount of fuel around 27 gal/hr
the gss317 is 255lph but only flows up to 90or so psi and after that it fall flat on it ***
Thanks Viren
I knew there was the 255 and the 255 high pressure just always thought they shared the same part # with two different versions
i always stick with the high pressure unit usually works great last abotu 2-3 years of good service life and it can handle up to 550hp not a prob at low fuel pressuer they flow damn good at 40-60psi of fuel pressure.
