quick question on skunk2 manifold install!!!
Old Nov 17, 2002 | 10:04 PM
boostedcvc's Avatar
Default quick question on skunk2 manifold install!!!
The manifold off my b18b has this sensor (indicated by arrow), the skunk2 manifold does not come with a place to locate the sensor. What did everyone do about it?
http://groups.msn.com/myboostedhonda...oto&PhotoID=49
http://groups.msn.com/myboostedhonda...oto&PhotoID=50
Old Nov 17, 2002 | 10:50 PM
boostaholic's Avatar
Default Re: quick question on skunk2 manifold install!!! (boostedcvc)
That's the evap sensor. If you take it off you will see a hole there for the vacuum source for that sensor. Since you said the Skunk manifold doesn't accomodate that sensor, you can tap into another vacuum source for the evap and mount it somewhere.
Old Nov 17, 2002 | 10:54 PM
Flamenco-T's Avatar
Default Re: quick question on skunk2 manifold install!!! (boostaholic)
it's an evap purge valve sensor, you can use any vac source for it and just mount it on the firewall or sumthin
stan
Old Nov 18, 2002 | 07:38 AM
boostedcvc's Avatar
Default Re: quick question on skunk2 manifold install!!! (Flamenco-T)
thats what i was planning on doing. thanks.
Wdpfreak145
May 15, 2013 07:06 PM
93delslow315
Apr 17, 2011 03:19 PM
madcrossover
Feb 12, 2007 08:03 PM
redintegra1998
Jul 14, 2005 10:43 AM
CsabaH
Nov 12, 2002 08:00 AM
