Quick Question, SC34
Old Mar 1, 2008 | 02:14 PM
kuja396's Avatar
Default Quick Question, SC34
Hey guys I'm sure this is been gone over before but I couldn't find it. I have a SC34 that I got with an old turbo kit. I was doing 250whp but that gets old so I'm doing a new build.
Question: How much whp can I get out of a SC34? I think it says .48 on the exhaust side and .60 on the cold side.
Plan is 450ish whp on a stock sleeve ls/vtec on pump gas.
I think I need a bigger turbo, looking at the SC61's. Let me know what you guys think!
Edit: don't know if it matters but its a 5 bolt.
Old Mar 1, 2008 | 07:56 PM
IceySC's Avatar
Default Re: Quick Question, SC34 (kuja396)
i had the sc34 turbo and 450 was my goal as well and everyone told me to sell it and get something bigger so i got the sc61 e housing.
Old Mar 1, 2008 | 08:14 PM
AMLS4dr200whp's Avatar
with a 48 I doubt u will research I say go with the sc61 turbo instead and upgrade I also have an sc34 but 57 with 63ar and I will see if I can push mine to 450whp
Old Mar 1, 2008 | 08:27 PM
xenocron's Avatar
Default Re: Quick Question, SC34 (AMLS4dr200whp)
450 is no problem on a sc34...i did it on my LSVTEC
Old Mar 1, 2008 | 08:42 PM
kuja396's Avatar
Default Re: Quick Question, SC34 (xenocron)
Hmmm I'm hearing a couple different things obviously.. Any more opinions? The thing I would hate the most is going to your tuner and not being able to put down what you want because my turbo ended up being too small. Theres $600 down the drain I suppose.
Old Mar 1, 2008 | 08:45 PM
11SECEG's Avatar
my friend made 422@ 20 psi .. this was on 84mm gsr
Old Mar 1, 2008 | 09:03 PM
kuja396's Avatar
Default Re: Quick Question, SC34 (11SECEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11SECEG &raquo;</TD></TR><TR><TD CLASS="quote">my friend made 422@ 20 psi .. this was on 84mm gsr</TD></TR></TABLE>
I'd be happy with 422, its just a street car.
Do you know what his AR on the turbo is for sure? like i said, im sure mine is .48ar hot and .60 cold.
Can someone explain how AR's work real fast?
Old Mar 1, 2008 | 09:41 PM
Turbo-charged's Avatar
my b16 made around 450 wtih an sc34 a few years back when it was my DD. .48 housing too
Old Mar 1, 2008 | 11:10 PM
kuja396's Avatar
Default Re: Quick Question, SC34 (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">my b16 made around 450 wtih an sc34 a few years back when it was my DD. .48 housing too</TD></TR></TABLE>
Thanks a lot for the info, looks like I'm keeping mine for a while now, no need to upgrade what I don't need to.
Old Mar 2, 2008 | 02:01 AM
IceySC's Avatar
im not saying it cant be done but your going to have to turn up the boost.
Old Mar 2, 2008 | 04:55 AM
Tjabo's Avatar
For Xenocron and Turbo-Charged especially (or anyone else with experience on point), what is the spool like on these SC34s, and how much sooner is it in general than an SC61?
Old Mar 2, 2008 | 06:03 AM
non-VTEC's Avatar
Default Re: Quick Question, SC34 (Tjabo)
made 420whp@17-18psi with a garret t3/to4b 57-trim w/.63ar...
is basically the same as the sc34.....i dont think 450whp is that out of reach......although i dont know how well the .48ar exhaust side will flow at that power level....
Old Mar 2, 2008 | 07:09 AM
xenocron's Avatar
I made 450 at 21.5 psi on my 10:1 Piston/Rod 81.5 mm LSV. Full spool by 5800 (or something like that) and a straight line boost all the way to 8200 redline.
.48/.63 57 trim SC34...this turbo is 4 years old too
Old Mar 2, 2008 | 08:36 AM
kuja396's Avatar
Thanks again for all the input
I did a little research and it looks like the SC34 is worth around $500 and a SC61 is about $600-$650. So I'll try to sell mine for $500 and if it doesn't sell I'll just keep it, if it does I'll get the SC61 for a little more on top, no big deal
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjabo &raquo;</TD></TR><TR><TD CLASS="quote">what is the spool like on these SC34s, and how much sooner is it in general than an SC61?</TD></TR></TABLE>
I can't compare to a SC61 obviously, but I have full boost at 4500 on a stock ls (running 16 lbs with a LOT of timing pulled so only about 280 whp ) with a Spoolin Performance LOG manifold.
Old Mar 2, 2008 | 08:40 AM
kuja396's Avatar
Default Re: Quick Question, SC34 (IceySC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IceySC &raquo;</TD></TR><TR><TD CLASS="quote">im not saying it cant be done but your going to have to turn up the boost.</TD></TR></TABLE>
I don't really care if I have to turn it up to 30 psi if it accomplishes what it needs to Should I be concerned about high boost levels on pump gas or something?
Oh and I have a minty condition SC34 for sale with NO shaft play $500
Old Mar 2, 2008 | 05:13 PM
1SlowSi's Avatar
I did 478whp @ 26 psi with an SC34. 26 was about all we could get out of it. 417whp @ 20 psi. It was definitely a fun turbo but lots of spin since it spooled so soon.
Old Mar 2, 2008 | 07:49 PM
da_dude's Avatar
I have a stage three 4 bolt .63 ar turbine housing if you ever want to upgrade it from your .48 ar.
turbo gsr2000
Jul 30, 2009 01:39 PM
akandok
Dec 23, 2006 08:00 AM
b20blkcivic
Jun 7, 2005 05:49 AM
