quick question... itr pistons in b18c
Old Dec 31, 2007 | 12:26 PM
conceptEG's Avatar
Default quick question... itr pistons in b18c
i just popped in itr pistons into my gsr. im looking to build a low boost set up.. can itr pistons handle 8lbs.. im using hastings rings and stock gsr rodds bushed to fit the itr slugs
thanks
btw i do see that theres a jrsc for the c5 that runs 8 lbs.. im just curious on opinions due to the c1 block and itr pistons.. i know my cr will be around 11:01
Old Dec 31, 2007 | 12:35 PM
kyden's Avatar
Default Re: quick question... itr pistons in b18c (conceptEG)
why would you put itr pistons in knowing you want to boost it?
and to answer your question, you could, but you're treading on thin ice.
Old Dec 31, 2007 | 02:50 PM
atec's Avatar
Your going to increase compression from 10:1- 10,8:1 by doing that.
Why dont change to a set of eagle rods and cp pistons.
Its not going to cost you much.
Old Jan 2, 2008 | 08:32 AM
conceptEG's Avatar
Default Re: quick question... itr pistons in b18c (atec)
i popped in the itr set up because it costed me around 38 bones a slug... timing belt and waterpump were a mere 60 bucks from work.. **** i paid more for the honing and rodds being busherd to fit the new slugs then i did for parts.
i just got this turbo kit cheap and i wanted to run it... not too much boost but like i said around 8 psi. in a gutted eg hatch that will be fine for me. im looking to make around 220-250 whp.
gsr96cx
Nov 17, 2007 07:45 PM
jikespingleton
Nov 22, 2006 11:47 AM
ghg78
Nov 16, 2005 11:38 AM
LoserKid
11
May 19, 2005 02:12 PM
Batoutahell
Mar 27, 2005 02:36 PM
