A quick question on injectors
Old Aug 27, 2005 | 12:38 PM
channy's Avatar
Default A quick question on injectors
I've got a set of DSM 450cc injectors and noticed that some guys had recommended using a dremel to take out some rubber on the stock honda o-rings. This doesn't sit to well with me and I was wondering if anyone has actually found an o-ring that works with these injectors and the b16a1 engine?
Old Aug 31, 2006 | 05:44 PM
Whiteintegra's Avatar
Default Re: A quick question on injectors (channy)
bump b/c i want to know too
Old Sep 1, 2006 | 05:56 AM
Turbo-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by channy &raquo;</TD></TR><TR><TD CLASS="quote">I've got a set of DSM 450cc injectors and noticed that some guys had recommended using a dremel to take out some rubber on the stock honda o-rings. This doesn't sit to well with me and I was wondering if anyone has actually found an o-ring that works with these injectors and the b16a1 engine?</TD></TR></TABLE>
Thats pretty much your only option other then getting some other injectors. why not pick up a set of precisions. you can get the on ebay for 249 shipped and there brand new and fit the correct way instead of rigging up some old used dsm's
Ive heard of peopel having those dsm injectors dropping out on them and leaning the motors out, but then again alot of people have success with them as well. did you have them cleaned and flow tested?
Old Sep 1, 2006 | 07:51 AM
Default Re: A quick question on injectors (Turbo-LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-LS &raquo;</TD></TR><TR><TD CLASS="quote">Thats pretty much your only option other then getting some other injectors. why not pick up a set of precisions. you can get the on ebay for 249 shipped and there brand new and fit the correct way instead of rigging up some old used dsm's
Ive heard of peopel having those dsm injectors dropping out on them and leaning the motors out, but then again alot of people have success with them as well. did you have them cleaned and flow tested?</TD></TR></TABLE>I have an in car wide band, so ill know if im going lean. And no, i have not had them cleaned or flow tested.
Del_Slo_b16
Engine Management and Tuning
31
Apr 21, 2012 09:29 AM
oneforce
May 24, 2007 10:43 AM
Project-D
Oct 12, 2006 04:19 AM
Sassafrass
Mar 17, 2004 06:30 PM
