quick question: deltagate (yes i searched)
Old Jun 20, 2003 | 03:03 PM
adhana2's Avatar
Default quick question: deltagate (yes i searched)
i got a 7-9psi stock spring on my deltagate... hwo do u change the PSI on these things?? thanks let me know
Old Jun 20, 2003 | 03:07 PM
civperc's Avatar
Default Re: quick question: deltagate (adhana2)
you can use a diff. spring, or a boost controller.
Old Jun 20, 2003 | 03:09 PM
adhana2's Avatar
Default Re: quick question: deltagate (untensadude)
i mean like if i wanna change the psi from 7 to 9 is that possible? or is it just set to a certain psi? sorry dont no much bout the deltagate
Old Jun 20, 2003 | 06:52 PM
Cramerox's Avatar
right now you probably have a 7lbs spring. to up the boost you can get a boost cntroller or change to a higher spring. i dont think u can really adjust the boost that much by tightening the wg.
Old Jun 21, 2003 | 12:16 PM
adhana2's Avatar
Default Re: quick question: deltagate (Cramerox)
oh ok...last question... how much boost can the deltagate handle??
Old Jun 21, 2003 | 12:47 PM
g2ls_turbo's Avatar
ok, for the delta gate, you loosen the bolt, you see how it has the lwrench, do a 1/4 of a turn, it will change psi, when its at the psi you want it, you just tighten back up the bolt and your done! i have 4 springs that came with mine, the highest psi spring is i think 9-13psi. im not using it, if your interested, make me an offer....good luck with the boost adjusting, 1/4 of a turn bumps up the psi.
Old Jun 21, 2003 | 01:45 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adhana2 &raquo;</TD></TR><TR><TD CLASS="quote">oh ok...last question... how much boost can the deltagate handle??</TD></TR></TABLE>
have you thought about selling it on ebay and buying a tial. if you want to up the boost with the deltagate you are asking for problems. it spikes bigtime.
Old Jun 22, 2003 | 04:48 PM
adhana2's Avatar
Default Re: quick question: deltagate (TeStUdO)
thanks g2ls_turbo... tat helped.. . yea i might be intersted but i dont no how much the springs sell 4 so i dont wanna lowball...how high can my psi pring go? 9psi?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
have you thought about selling it on ebay and buying a tial. if you want to up the boost with the deltagate you are asking for problems. it spikes bigtime.</TD></TR></TABLE>
yea i have tought bout a tial but if deltagate can take 10 psi (which i am planning on runnin till i go with a built motor) then i am aite... i got it 4 cheap tatz y i decided to run this.
Old Jun 22, 2003 | 05:42 PM
civperc's Avatar
just be careful then. keep an eye on your boost gauge A LOT, cuz those deltagates are known to kill engines by letting the psi climb climb climb.
1990hondaHF
Jan 16, 2008 11:57 AM
vg7z
Sep 20, 2006 08:27 PM
freeplay
Sep 4, 2003 06:38 PM
Dancing is Forbidden
Feb 16, 2003 08:42 AM
zojirushi
Jan 23, 2002 04:42 PM
