Quick question......10.6 compression too high?
Old Oct 25, 2006 | 11:10 AM
Dat1BVtecN's Avatar
Default Quick question......10.6 compression too high?
10.6 - 10.8 compression too high for turbo? 5-7 lbs daily driver, weekend 8-12 lbs. Good tuning with Hondata S200.
Old Oct 25, 2006 | 11:27 AM
NJcoupe's Avatar
Default Re: Quick question......10.6 compression too high? (Spoolin4u)
B16's are in the low 10.x's stock. So honestly, its all in the tune.
Edit Curious why the s200 instead of the s300?
Old Oct 25, 2006 | 07:51 PM
Dat1BVtecN's Avatar
soooooo, if great tuning, than yea it should be pretty safe and reliable?
Old Oct 25, 2006 | 07:59 PM
PinkMaggit's Avatar
yea just dont push it up too much.
People have boosted stock Itr's to 8-10lbs. 11:1 compression.
Supercharged and turbo charged.
Use cold plugs and gap them a tad smaller and get it tuned.
Old Oct 25, 2006 | 08:09 PM
Dat1BVtecN's Avatar
Default Re: Quick question......10.6 compression too high? (PinkMaggit)
all i wanted to know, thanks guy!
Old Oct 25, 2006 | 09:20 PM
Makdaddynuge's Avatar
i've got the jdm gsr motor which is 10.6:1. Boosting 9 lbs. But this car i only drive maybe once a week. And i am constantly tuning it to make sure its always running perfect
Old Oct 25, 2006 | 10:21 PM
SOHC_me's Avatar
Default Re: (Makdaddynuge)
what kind of advantage would it be, would it be quicker spool up?
Old Oct 25, 2006 | 11:14 PM
ExospeedAMcrx's Avatar
depends on the Engine and Bore size. What engine are you using and which Bore size?
Old Oct 25, 2006 | 11:17 PM
SOHC_me's Avatar
Default Re: Quick question......10.6 compression too high? (exospeedAMcrx)
stock ls. stock bore i guess, i was just woundering if i bumped the compression up to 10.5 if it would help spool up quicker? Is there a way i can make it spool up faster?
Old Oct 25, 2006 | 11:21 PM
Default Re: Quick question......10.6 compression too high? (SOHC_me)
The reason I ask is. Theres a difference between:
D16 75mm 10.6:1
vs
B18 81mm 10.6:1
vs
B18 84mm 10.6:1
vs
B16 81mm 10.6:1
vs
B16 84mm 10.6:1
Piston design changes with each of te motors, Bore size and the type of combination with the cylinder heads.
We usually run 84mm Flat top 10.9:1 pistons on alot of our race motors. Its still a good design for turbo due to its flat top design. You just want to stay away from the more Dome style pistons for turbo.
10.6:1 isnt really a big compression so in general its a good compression for turbo.
Old Oct 25, 2006 | 11:25 PM
SOHC_me's Avatar
reason asking bc a friend has cp pistions that give me a 10:5:1 cr, thats just what he told me, i don't know if it does, it wols be going into a totaly stock ls engine, so i don't know if those pistions have a lot of dome or not, but thanks for the info
Old Oct 26, 2006 | 07:48 AM
RyanEJ8's Avatar
I'm running 10.5:1 SRP pistons in my D16, but when I calculated the compression out it came out to more like 10.1:1 for some reason. It's working out good so far at 14 psi, see sig. I'll eventually raise the boost with a race gas tune.
Old Oct 26, 2006 | 10:16 AM
Bseriescivic5's Avatar
I run 10:6:1 20psi on 81.5 mm b16a no problems all in the tune.
Old Oct 26, 2006 | 10:24 AM
Dat1BVtecN's Avatar
Default Re: (Bseriescivic5)
wow! stock sleeves and ****?
Old Oct 26, 2006 | 12:31 PM
pistons+rod motor slight head work, stock sleeves. Stock sleeves can handle 600+ HP thats not the issue at all as long as you have a good tune!!
Old Oct 26, 2006 | 12:35 PM
ALLMOTA92EG's Avatar
Anyone have any high comp setups they would like to share?
Old Oct 26, 2006 | 01:24 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (Jdmcivichb!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmcivichb! &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any high comp setups they would like to share?</TD></TR></TABLE>
i will soon...
Old Oct 26, 2006 | 01:32 PM
BLKTeg94's Avatar
Mr Green earlier on this year had his motor at 12.2-12.5 compression with 40 psi... destoryed a piston, compressed into two little *****. Went way lean due to a bad wideband. $300 part cost him $5,000.
Old Oct 27, 2006 | 12:25 PM
turboteener's Avatar
Banned
I am running something on the order of 11.1 on my d16. It runs 13psi and a 230psi of cranking pressure. Haven't dynoed it yet. I want a bigger turbo first.
Old Oct 27, 2006 | 12:32 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (turboteener)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboteener &raquo;</TD></TR><TR><TD CLASS="quote">I am running something on the order of 11.1 on my d16. It runs 13psi and a 230psi of cranking pressure. Haven't dynoed it yet. I want a bigger turbo first.</TD></TR></TABLE>
hows that working for you??
i goign with a 10:5 for my Z6
Old Oct 28, 2006 | 06:41 AM
Banned
I haven't had any problems with it. I did have a couple of issues with the pistons hitting the heads when I mocked up the engine. After opening the chambers and equalizing the quench pads, problem solved. It is tougher to tune timing though. You have to be very conservative to start out and work slowly.
I want to up the boost but this turbo is so far out of its efficiency range that I doubt it would do anything for me.
Old Oct 28, 2006 | 11:36 AM
racin jasin R's Avatar
sounds like a good set up to me.will spool up nice and quick.........
Old Oct 28, 2006 | 12:21 PM
whiteef8's Avatar
Default Re: (racin jasin R)
nothing at all wrong with boosting a 10.5:1 motor, i wouldnt recommend it if youre looking to run it daily on the street, because 9:1 or 9.5:1 pistons are just a cheap and available, and less prone to detonation. Just think, one bad tank of gas and your built motor is gone, what you have to look at is how often youll be driving this vehicle, and what youll be doing with it good luck
HarfordCTR
Dec 21, 2007 07:06 PM
iwanttogofast
Feb 26, 2007 03:29 PM
CivicDude2k4
18
Oct 8, 2006 09:13 PM
Soon_2b_evil
Nov 16, 2003 07:41 PM
s0liDyNe
Jul 19, 2003 10:24 PM
