quick JDM H22A question...
Old Mar 23, 2005 | 01:49 PM
turboH22Aakkord's Avatar
Default quick JDM H22A question...
almost ready to tune the ol gal... but i ran into a simple lil problem i think....Im running uberdata, and to setup my basemap i need to imput the old injector size... but with a H22A there are different sized injectors depending on wether they were OBD1 or OBD2 (from what im told) ... i put the engine in my accord, but i have no idea what year the engine was... what i need to know is a quick way to tell what year the H22A is... thanks guys!!
Old Mar 23, 2005 | 02:29 PM
Default Re: quick JDM H22A question... (turboH22Aakkord)
anyone? ... is there a time stamp or a specific color of injectors or something? thanks...
Old Mar 23, 2005 | 02:35 PM
forcefedh22's Avatar
which side of the fuel rail is the gas feed line on? If it is on the passengers side it is obd1, If it is on the drivers side it is obd2.
Old Mar 23, 2005 | 02:48 PM
Default Re: quick JDM H22A question... (accordh22turbo)
another thing.. the vin will be on the back of the motor.
Old Mar 23, 2005 | 04:50 PM
93hatched_projekt's Avatar
check the stamp on the head. If it's a h22a from 92-96 most likely their 345cc.
Old Mar 23, 2005 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordh22turbo &raquo;</TD></TR><TR><TD CLASS="quote">which side of the fuel rail is the gas feed line on? If it is on the passengers side it is obd1, If it is on the drivers side it is obd2.</TD></TR></TABLE>
I would not go off this info , My line is on the driver side and it's obd1.
Old Mar 23, 2005 | 05:06 PM
Dragline's Avatar
Default Re: quick JDM H22A question... (93hatched_projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt &raquo;</TD></TR><TR><TD CLASS="quote">check the stamp on the head. If it's a h22a from 92-96 most likely their 345cc.</TD></TR></TABLE>
It's stamped on the head inbetween the valve cover & the exhaust manifold or header.
Old Mar 23, 2005 | 06:16 PM
PrecisionH23a's Avatar
Default Re: quick JDM H22A question... (dragline)
If you are not running a resistor box with the swap... my guess is it is the 290cc's. If you are running the resistor box, it is most likely the 345cc's.
My guess is you are trying to figure out the injector multiplier values? Even if you input the wrong values there are ways to get around that But then again... I don't mess with uberdata often so I could be mistaken.
Old Mar 24, 2005 | 06:02 AM
God bless HT... haha.. thanks for all your help!!! two
Old Mar 24, 2005 | 11:55 AM
O3DigitalBath's Avatar
...lol just look at the clips?
is it just me or do obd1 clips always have the lil metal **** and obd2 are all the squeeze clips, obd1 are gray and obd2 are black....(stock ones)
seems like everyone is trying to figure it out the hard way...
pleej
Jan 31, 2016 02:24 AM
SOIBEANS
Apr 4, 2005 10:01 AM
ZexyAccord
Mar 3, 2005 05:53 PM
RotiEatter
Jan 26, 2003 10:09 PM
