quick DSM 450cc injector question
Old Apr 8, 2003 | 10:55 PM
_Endless_'s Avatar
Default quick DSM 450cc injector question
i bought a set of DSM 450cc injectors and the shop who sold it to me also gave me the injector seal that goes over the pintle cap. i'm going to do the hack, will i be using those or do i use the stock honda injector seal? here's a pic of the DSM seal i'm talking about...
if pic don't work, please take a look at this link:
http://www.pbase.com/image/15264126
any help will be appreciated.
[Modified by _Endless_, 7:56 AM 4/9/2003]
[Modified by _Endless_, 7:57 AM 4/9/2003]
Old Apr 8, 2003 | 11:20 PM
genop's Avatar
Default Re: quick DSM 450cc injector question (_Endless_)
If you use the stock seals you will have to bore them out a little for the injectors to fit right. I dont know about the DSM seals though.....
Old Apr 9, 2003 | 12:01 AM
inspyral's Avatar
Default Re: quick DSM 450cc injector question (genop)
I used my stock Honda seals, no problems whatsoever.
Old Apr 9, 2003 | 12:02 AM
_Endless_'s Avatar
so you guys are saying that i don't need the seal that came with the injectors which can be seen on the pic?
Old Apr 9, 2003 | 01:31 AM
LJR-LUDE01's Avatar
red x.... i have dsm 450 just bore your stock seals and they should work... but make sure not to bore them to much.. or you might get a fuel leak... for the ones that you show on the pics you don't need those
Modified by LJR-LUDE01 at 11:30 PM 4/9/2003
Old Apr 9, 2003 | 02:22 AM
GOLDBERG's Avatar
no..take it off or its gonna endup falling into the intake manifold most likely and then into the engine..
Old Apr 9, 2003 | 06:10 AM
Tony Starks's Avatar
Default Re: quick DSM 450cc injector question (GOLDBERG)
Do this. DO NOT USE YOUR STOCK SEALS.
1. Injectors seals: Napa sells an injector seal kit that contains seals for Civics and Integras. Because I have a Civic, the taller Integra seal works out perfect for me! If you don't need the complete seal kit, just go to Acura and buy only the bottom seal, or try to find some taller seals that have the same outside dia.
2. Bore out the bottom seals: I find it much easier to bore out the seals with a Dremel and do it in the manifold. I simply use a stock manifold that I have sitting around and use it to hold the seals. It only takes seconds to bore each seal!
3. Finished product: If done properly (which is extremely easy), it will look like stock.
4. Injector tip protruding distance: This is the good part. With the properly selected bottom seals, the injector tip protruding distance in the manifold can be the same as stock and still allows the injectors to sit flush on the seals! Btw, the injectors should go on the seals with slight friction.
Stock injectors with seal.
DSM injectors with taller seal.
5. Installed DSM injectors: The injectors fit very nicely in the JRSC intake manifold with the taller seals.
Here's a closeup, nice and flush!
Old Apr 9, 2003 | 07:16 AM
Burke's Avatar
Banned
Default Re: quick DSM 450cc injector question (Tony Starks)
will the same seals work for a b18b?????
i see you (tony) have a d16y8.
Thanks
Old Apr 9, 2003 | 07:57 AM
hypa's Avatar
Default Re: quick DSM 450cc injector question (Burke)
Kickass reply Starks!
Old Apr 9, 2003 | 08:01 AM
integranator's Avatar
So-- I guess you'll never know how it fits, until you have your injectors, and you're looking at the manifold, correct?
Edit: And how much do you need to bore out??
Old Apr 9, 2003 | 08:21 AM
Default Re: (integranator)
Thanks for the love guys, but I can't take credit for the write up. I can't remember who did it, but yes, it does kick ***. They will work for a B series, infact, those seals are for a B series motor. Use a dremel with their standard sanding tool, just like the one in the pic. Its exactly the correct size. Try not to mess up. Those seal kits are like $8 bucks a pop. Its the only good way to run DSM's.
Old Apr 9, 2003 | 09:01 AM
Default Re: (Tony Starks)
If you don't have a spare manifold, I've got a couple. ****, you can have the extra Y7 mani I have for free. Just pay for shipping.
Old Apr 9, 2003 | 09:45 AM
dfoxengr's Avatar
Default Re: quick DSM 450cc injector question (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">I used my stock Honda seals, no problems whatsoever.</TD></TR></TABLE>
just had to smush them in a little
K7-1Ktrevor
Dec 3, 2009 10:49 AM
egturbo
Dec 30, 2003 06:47 PM
Elite Hatch
Sep 18, 2002 01:34 PM
seekerONE
Jun 14, 2002 03:00 PM
