quick bov question
Old Nov 28, 2006 | 01:02 PM
wrx'n you's Avatar
Default quick bov question
i was given a bov for free from my friend. it is a ebay xspower bov, i really dont know which model or whatever. but my question is on the top of the bov there the nipple is, isnt it suppose to be sealed and so tthat no air can get in or out or is it suppose to let a little air in/out?
Old Nov 28, 2006 | 01:09 PM
BoostedEG6's Avatar
Default Re: quick bov question (projEKt B)
ummm thats where the vac line goes
Old Nov 28, 2006 | 01:19 PM
wrx'n you's Avatar
Default Re: quick bov question (BoostedEG6)
yeah i know but is it supposed to be sealed so that no air comes in/out or is it supposed to let a little air in/out. cause i really dont know if i should use this bov or not. and does anyone know what knock-off this bov is suppose to be?
Old Nov 28, 2006 | 01:59 PM
BoostedEG6's Avatar
ok.... it seems to me that you dont really know how a BOV works. I am not trying to be a dick or anything so dont get me wrong....
You have to put a vac line on the nipple and run that to your manifold or a Vac manifold.... there is a spring inside that along with the Vac line (that will also see pressure when you are in boost) keep it closed. When you let off the gas the vac line releases the pressure and the spring and vac will cause the valve to open letting air out of the charge pipes via the holes near the bottom of it
I hope this helps you and you understand what I am saying..... lol its 2am here and I have been drinking so bear with me
Old Nov 28, 2006 | 03:55 PM
wrx'n you's Avatar
but it seems like the seal is bad or something on the bov and i think it might just leak boost when it is installed.
Old Nov 28, 2006 | 04:28 PM
memorybox's Avatar
all the top does is read vaccum, hook a vaccum line up to it and your good to go. it has to read the air so it can open and go "PSSSHHTTTT"
Old Nov 28, 2006 | 06:45 PM
wrx'n you's Avatar
Default Re: quick bov question (memorybox)
yeah but i have a feeling when i put this bov on, i will get a boost leak. i blew into the nipple so see if it was sealed or not and it wasnt.
Old Nov 28, 2006 | 07:14 PM
aaronISthrowed's Avatar
Post a pic.
Old Nov 28, 2006 | 08:06 PM
Attaus's Avatar
Install it and see what happens. Boost leak won't kill you.
Old Nov 29, 2006 | 04:20 AM
wrx'n you's Avatar
Default Re: (Attaus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Post a pic.</TD></TR></TABLE>
pic is in first post
Old Nov 29, 2006 | 01:33 PM
Attaus's Avatar
Yeaaaahh.. that's where you insert the vacuum source.
Old Nov 29, 2006 | 03:54 PM
TIGboy's Avatar
its supose to be solid.
DelSeeYa
Oct 7, 2009 11:07 AM
crooklyn_outlaw
Oct 24, 2008 07:18 AM
Bboy_Trevstuh817
May 2, 2007 11:56 PM
boostedcoupe
Nov 21, 2002 10:24 AM
jdm_latino
May 20, 2002 08:52 AM
