Question for ya folks
Old Jun 13, 2002 | 06:10 AM
TurboT's Avatar
Default Question for ya folks
does anyone know if the OBD2.5 version engines..
1999-2001 GSR engines specifically...
have different sensors than the OBD2 engines from the 96-98 years?
my speedometer and temperature gauge is acting all screwy....
as soon as you turn the key and give the car some voltage...
the needles jump up to about 40% of the full range...
i can't figure it out...
the car isn't moving and it says i'm going 45 MPH
and the car isn't even on, and the temp is between cold and the middle...
any ideas?
stumped and scratching my *****.... opps, i mean my head
Old Jun 13, 2002 | 06:11 AM
TurboT's Avatar
Default Re: Question for ya folks (TurboT)
also, anyone know how to properly check operation of the water pump?
and proper operation of the thermostat?
Old Jun 13, 2002 | 06:25 AM
BoOsTeD_eK's Avatar
you might have fluid in your connectors...causing a short when you apply voltage to the sensors...unplug it and BLOW!
Old Jun 13, 2002 | 06:28 AM
TurboT's Avatar
Default Re: Question for ya folks (BoOsTeD_eK)
i know that's not happening...
because i thought the harness was the problem and swapped my 1998 harness onto the motor...
Old Jun 13, 2002 | 07:33 AM
TurboT's Avatar
Old Jun 13, 2002 | 08:26 AM
TurboT's Avatar
Old Jun 13, 2002 | 10:24 AM
BROOD's Avatar
I checked out some numbers: for a 1998 verses a 2000 GS-R
Water temp thermosensor is the same p/n
The VSS speedo unit is the same p/n
I would say that rules out the possibility of different sensors causing this problem.
I'm guessing a possible short somewhere in the wires as well.
Only way I've ever checked the proper operation of the thermostat and coolant pump is by taking them off the engine. Otherwise if you start a cold engine you can tell when the thermostat opens up by touching the upper rad. hose. It will turn very warm, very quickly when the thermostat opens. You could check that the coolant pump is circulating coolant by splicing a clear tube in-line one of the heater core hoses. Personally I would still inspect then off of the engine.
[Modified by SLPR, 11:25 AM 6/13/2002]
[Modified by SLPR, 11:54 AM 6/13/2002]
Old Jun 13, 2002 | 10:44 AM
inspyral's Avatar
Default Re: Question for ya folks (SLPR)
Have you checked the fueses? I know there's a VSS fuse under the dash that made my speedo act nuts when it was out.
Old Jun 13, 2002 | 11:09 AM
TurboT's Avatar
Default Re: Question for ya folks (inspyral)
i checked the under dash fuses...
i'll check again...
i'll try and get a new cluster and see what happens...
thanks for the good info
Zukka
Aug 24, 2011 11:00 AM
01_ITR
Oct 6, 2008 05:42 AM
hbyrd8701
Jul 26, 2006 07:44 AM
TURBODC4TEG
Aug 4, 2005 10:45 AM
