question on using gaskets...........?
Old Oct 28, 2003 | 05:29 PM
Acura_I-RS's Avatar
Default question on using gaskets...........?
just wondering if i should use a gasket between the turbo/manifold, and also between the turbine housing and downpipe??
how many do, how many dont??
Old Oct 28, 2003 | 05:32 PM
johnmay19's Avatar
Default Re: question on using gaskets...........? (Acura_I-RS)
I don't and have had no problems.
Old Oct 28, 2003 | 06:45 PM
11psiTurboSI's Avatar
Default Re: question on using gaskets...........? (johnmay19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johnmay19 &raquo;</TD></TR><TR><TD CLASS="quote">I don't and have had no problems.</TD></TR></TABLE>
Same here
Old Oct 28, 2003 | 07:05 PM
SMOOTH97LUDE's Avatar
Default Re: question on using gaskets...........? (9psiTurboSI)
i have a gasket between my maxrev mani and the turbine but nothing between downpipe and turbine
Old Oct 29, 2003 | 03:12 PM
Acura_I-RS's Avatar
Default Re: question on using gaskets...........? (SMOOTH97LUDE)
well, i think mine is leaking between the mani and turbo a little bit, bit i have heard about epople getting leaks a lot more when using a gasket, so i was maybe just going to have them both leveled off at a machine shop to make sure thye are even, so it would seal properly..... cuz i have a .48 exh housing on my merkur turbo on my integra ls, and it doesnt spool fully until about 5k rpms or so...
Old Oct 29, 2003 | 05:08 PM
Foozball26's Avatar
i only have a firering gasket between the wastegate and manifold and I really don't even need that one.
we don't need no stinking gaskets
Old Oct 29, 2003 | 07:22 PM
Bailhatch's Avatar
Default Re: question on using gaskets...........? (Foozball26)
If you have both peices surfaced and use a little copper spray it would be an ideal setup IMO. Try to use through bolts too, or at least studs.
Old Oct 29, 2003 | 07:30 PM
Johnyquest's Avatar
OUCH. .48 housing on my t3 d16z6 civic has full 10psi by like 3900/4000
da_dude
Aug 19, 2007 05:16 PM
95dc2teg
Jul 17, 2006 01:26 PM
hoya_10fintec
Dec 24, 2005 10:37 PM
DaX
Apr 4, 2005 08:34 AM
4-banging
Mar 15, 2004 12:03 PM
