Question on Rev Hard Turbos
Old May 30, 2004 | 05:57 PM
HS2G's Avatar
Default Question on Rev Hard Turbos
I'm planning on going with a rev hard turbo kit. The stage 1 sounds pretty good, but then the stage 2 doesn't look so bad either.
So heres my question. Has anyone had a stage 1 or stage 2 that can tell if there is any lagg time difference between the two? At what RPM is the stage 1 and stage 2 going to give me full boost?
Old May 30, 2004 | 06:00 PM
94gsr4dr's Avatar
Default Re: Question on Rev Hard Turbos (HS2G)
Many things factor in to when it will spool, but my friends si with 2.5 downpipe and non turbo n1 spooled a stage 2 around 4500. Pretty shitty spool for a turbo that small (t3/to4b). Made like 245 at 7 pounds or something like that.
Old May 31, 2004 | 09:37 AM
Vtec92Civic's Avatar
Default Re: Question on Rev Hard Turbos (94gsr4dr)
there are 2 many factors such as what motor you have . . . . if you have any sort of internals or headwork done etc . . . . you'll prob. hit full boost depending on how much you plan to boost at about 4,000rpms
Old May 31, 2004 | 11:58 AM
G
sh!t happens.
Default Re: Question on Rev Hard Turbos (Vtec92Civic)
i have the stage 2 and i love it..but its for sale
Old May 31, 2004 | 01:59 PM
92turbocvchatch's Avatar
i have the stage 2 it spools at about 4700. they can make some power too.
i have mine tuned to 15psi 340 hp and 19psi 360hp. the difference
is at the higher boost levels its not efficient
99blusi
Feb 7, 2004 08:36 AM
Full-Race Geoff
May 9, 2003 06:00 PM
lucas569
Dec 1, 2002 11:12 PM
txhatch
Jan 24, 2002 11:42 AM
JohnnyM
Sep 23, 2001 08:43 PM
