QUESTION PLEASE HELP DUTY CYCLE...
Old Oct 10, 2005 | 08:14 PM
9SECQTR's Avatar
Default QUESTION PLEASE HELP DUTY CYCLE...
ok we started tuning my car again tonight and at 23psi it made 465 but the problem we are seeing is the duty cycle is up at 97% with 1000cc injectors, a1000 fuel pump and 55psi of static FP. Does n e 1 have an idea why we are running out of injector???
Old Oct 10, 2005 | 08:30 PM
boosted k20's Avatar
Default Re: QUESTION PLEASE HELP DUTY CYCLE... (9SECQTR)
what r u tuning the car with? if ur tuning with uberdata then dont worry about the duty cycle funtion. it is not accurate
Old Oct 10, 2005 | 08:33 PM
dunkd's Avatar
he has AEM EMS being tuned by jdogg
Old Oct 10, 2005 | 08:57 PM
dunkd's Avatar
bump
Old Oct 10, 2005 | 09:55 PM
.dave's Avatar
i HAS questions ?
Default Re: (dunkd)
Have you checked all physical aspects of your fuel system? The only thing I can think of is that your fuel pressure may not be rising with boost pressure.
Old Oct 11, 2005 | 09:37 AM
dunkd's Avatar
Default Re: (daveG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked all physical aspects of your fuel system? The only thing I can think of is that your fuel pressure may not be rising with boost pressure.</TD></TR></TABLE>
fuel pressure is rising with boost.
Old Oct 11, 2005 | 11:23 AM
seen4ever's Avatar
Default Re: (dunkd)
is the wideband correct? what's teh A/f? just asking cause maybe wideband says 11.5 but is really 9.8...
how do the plugs look?
do you have the right injector selected within AEM? is the multiplier correct?
what size lines are you running to and from pump to rail? is the gas tank sumped?
Old Oct 11, 2005 | 11:44 AM
9SECQTR's Avatar
Default Re: (seen4ever)
wideband is fine and the plugs are mint yea jdogg is doing all the tuning and i am sure it is correct, i have -8an lines and yes the tank is sumped
Old Oct 11, 2005 | 12:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (9SECQTR)
you may have a top end volume issue. like lines and a fuel pump that isnt up to the wask. it isnt always the pressure that you need. it is the physical volume of the fuel that you need.
Old Oct 11, 2005 | 02:14 PM
dunkd's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">you may have a top end volume issue. like lines and a fuel pump that isnt up to the wask. it isnt always the pressure that you need. it is the physical volume of the fuel that you need.</TD></TR></TABLE>
everything he has is top of the line and brand new.
Old Oct 11, 2005 | 02:17 PM
flip1199's Avatar
what's the fuel pressure at @ 23lbs?
Old Oct 11, 2005 | 02:35 PM
dunkd's Avatar
im pretty sure it rises to 65-70
Old Oct 11, 2005 | 03:22 PM
9SECQTR's Avatar
Default Re: (dunkd)
70psi at 23psi i thought it maybe the filter or something only cause i figured we would be closer to 100psi of FP at 23psi
Old Oct 11, 2005 | 04:58 PM
flip1199's Avatar
shoudnlt it rise i psi for every psi of boost so for 55psi fp and 23psi of boost shouldnt it be around 78?
Old Oct 12, 2005 | 06:56 AM
seen4ever's Avatar
Default Re: (flip1199)
what filter are you running? i remember aeromtoive wants you to run dual filters. you said -8an line, it is -8 feed and -8 return?
something is up with fuel volume, where is the pump at in position to your tank sump? shoot some pics, i know the pump has to be within a small distance and no more than a few inches taller.
but if running the std aeromotive regulator, shoudl rise 1lb per 1 psi.
how is the fpr run? -8 line?
are you sure they are 1000s?
what's your vacuum source to the regulator?
Old Oct 12, 2005 | 07:10 AM
11SEC CIV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seen4ever &raquo;</TD></TR><TR><TD CLASS="quote"> are you sure they are 1000s? </TD></TR></TABLE>
Donnie, Dave and I were thinking the same thing
Old Oct 12, 2005 | 07:15 AM
b18bturbo's Avatar
the part number ont eh 1000cc should be 17113744 for the delphi rochester injector which you probably have just check the side for the part #
BobbyRodriguez
Oct 9, 2011 08:37 AM
boost4s2k
Jul 29, 2009 11:59 AM
4drEF
Mar 18, 2009 07:32 PM
wfocrx
May 3, 2007 09:28 AM
Quick 200k Mile Motor
Jun 29, 2003 05:48 PM
