~325whp on 550cc's?
Old May 2, 2007 | 10:11 AM
wfocrx's Avatar
Default ~325whp on 550cc's?
I have a set of 550cc injectors and was wondering if they will be good for ~325whp? I have a adjustable fpr and was thinking about setting the fpr at ~55psi. will they be enough?
Old May 2, 2007 | 10:20 AM
A.E Motoring's Avatar
Default Re: ~325whp on 550cc's? (wfocrx)
yes
Old May 2, 2007 | 10:24 AM
mike1114's Avatar
Default Re: ~325whp on 550cc's? (Dual Cam Racing)
yes, I made 311 on DSM 440CC before I had to change them out so 550CC should hit 325 no problem.
I am assuming this is D or B series.
Old May 2, 2007 | 10:55 AM
White Smoke's Avatar
i my honda
Global Mod
Should have no problems.
Old May 2, 2007 | 11:30 AM
h22silvia's Avatar
hit 406 whp on 550 on a gsr
Old May 2, 2007 | 01:17 PM
boosted k20's Avatar
Default Re: (h22silvia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22silvia &raquo;</TD></TR><TR><TD CLASS="quote">hit 406 whp on 550 on a gsr</TD></TR></TABLE>
damn, u must be at 100% duty cycle. 350whp w/ base fuel pressure at 40 psi should be fine on 550cc
Old May 2, 2007 | 01:19 PM
ProJectCvic's Avatar
Default Re: (boosted k20)
probably up the fuel pressure
Old May 2, 2007 | 05:40 PM
2redstars's Avatar
made 349whp w/ 550's, and thery were almost maxed. added some fuel pressure to give a little extra room
Old May 2, 2007 | 08:29 PM
wfocrx's Avatar
is it ok to run at 55psi fuel pressure?
I know that turbo dodges (both old and the srt4s) run at 55psi.
Old May 2, 2007 | 11:33 PM
HiProfile's Avatar
Default Re: (wfocrx)
If you run 10psi of boost or less, 55psi wouldn't be bad, as that's making the fuel pump push up to 65psi (stock fuel reg is 1:1 rising rate).
325whp with 550's would probably get you around 85-90% duty cycle, which is about as far as you want to take injectors. You could get towards 400 with a good fuel pump and a good bump in fuel pressure, but if it ever spikes (or you want more later), you're SOL.
Old May 2, 2007 | 11:46 PM
slowsi00's Avatar
hahah 440cc support 400whp
just gotta have enough fuel pressure for the LOSS.
Old May 3, 2007 | 07:40 AM
Default Re: (slowsi00)
And what fuel pressure is that??? That's a bit pushing it. TOO high fuel pressure for my taste when larger fuel injectors these days are cheap.
Old May 3, 2007 | 09:04 AM
slowsi00's Avatar
Default Re: (ProJectCvic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic &raquo;</TD></TR><TR><TD CLASS="quote">And what fuel pressure is that??? That's a bit pushing it. TOO high fuel pressure for my taste when larger fuel injectors these days are cheap. </TD></TR></TABLE>
i dont reccomend it either. it was a band-aid.
just couldnt get anything but 440cc to work
Old May 3, 2007 | 09:28 AM
envee's Avatar
240cc = 180-190whp
310cc = 200-220whp
370cc = 220-280whp
440cc = 280-330whp
550cc = 330whp-380whp
660cc = 380whp-425whp
720cc = 425whp-475whp
880cc = 475whp-525whp
1000cc = 525whp-600whp
Taking directly from john vegas site.
the.hamburglar
Mar 27, 2015 07:58 AM
hksitr
11
Jul 27, 2013 12:07 AM
b00stedbyFastrax
Dec 13, 2007 06:21 PM
aalb1
Nov 2, 2005 10:47 AM
