Question on my setup
Old Apr 21, 2007 | 11:55 AM
JLHDOHC's Avatar
Default Question on my setup
Ok just got my setup together currently running a Darton 84.5mm sleeved Gsr block Stock crank eagle rods and wiseco 8:8:1 compression pistons Arp everything on bottem end and headstuds, head has some work done to it factory size fearra valves and Jg dual valve springs and retainers with Gsr cams victor X intake manifold with a s2000 throttle body Full-race T4 top mount divided wastegate manifold and a Gt4088r with a 4inch downpipe I wanna know what spark plugs to use on this setup and if the Gsr cams are going to be Ok fuel system is deffenetly setup for this setup Aeromotive pump and regulater on a fully sumped and all 8an braided lines with 6an return golden eagle rail. All controlled on a full standalone system....any more suggestions would be great looking for some axles so I can run it down the track on my 24.5x9x13 slicks if anyone as some let me know thanks Josh
Old Apr 21, 2007 | 12:55 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Question on my setup (JLHDOHC)
i will say 8's. i use 8's in iridium.
Old Apr 23, 2007 | 08:34 PM
JLHDOHC's Avatar
Default Re: Question on my setup (boostedcivicsir)
whats your setup and do you mean 8's in NGK
Tuner Eddy
Apr 21, 2014 07:31 AM
Tuner Eddy
Appearance Build Threads
Apr 15, 2014 04:49 PM
Tuner Eddy
Apr 13, 2014 03:14 AM
bertsb18hatch
14
Dec 8, 2010 10:35 PM
slowteg550
Apr 16, 2006 03:55 PM
