Question on map sensor
Old Oct 24, 2007 | 01:06 PM
ekk41's Avatar
Default Question on map sensor
I'm wondering if i need a map sensor if i'm only going to be running maximum 10psi and if i do run it now without a 3 bar map sensor and i get it tuned on crome or s200 will i need to retune it later if i do get a 3 bar map sensor this is on a d16y7
Old Oct 24, 2007 | 01:35 PM
Schister66's Avatar
Man U FTW
you dont need a 3bar map at this point, but it wouldnt be a bad idea to get one now if youre planning to upgrade in the future. Your future tunes will take less time if they can just adjust the current tune rather than redoing the entire thing just to change the map sensor. I wish i would have gotten a 3bar right away
Old Oct 24, 2007 | 02:04 PM
ekk41's Avatar
Default Re: (Schister66)
Thanks alot heres another question how much can i boost on maximum 1 bar? since all stock cars are set at 1 bar if i am correct
Old Oct 24, 2007 | 02:22 PM
Schister66's Avatar
Man U FTW
IIRC stock Honda maps are 1.8 bar map sensors. You have to account for 1 atm of static pressure in the atmosphere. Therefore a stock map will read ~11.6psi.
A GM 3bar will read 29psi
An AEM 5bar will read 58psi
Old Oct 24, 2007 | 05:28 PM
ekk41's Avatar
wow thanks haha so i guess for now i dont need a 3bar map sensor because i'll be putting down 10psi max for now until i build my motor
sdbee84
Jan 31, 2016 11:20 AM
ekk41
Oct 24, 2007 05:16 AM
KRWTEK1
May 28, 2007 12:32 AM
TurboGS-R
Aug 18, 2005 01:28 PM
95turbogsr
Jun 25, 2005 03:01 PM
