Question Ls Crower 402t
Old Feb 3, 2006 | 04:25 AM
TURBODC4TEG's Avatar
Default Question Ls Crower 402t
I just bought a set of cams from a guy on here, when i get them i want to know how i can identify if they are the 402ts or 402 na. that way i know if i got scammed. i searched can't find anything
Old Feb 3, 2006 | 07:37 AM
AMLS4dr200whp's Avatar
Default Re: Question Ls Crower 402t (TURBODC4TEG)
I got them too and my friend told me it suppose to say just 402 on the side of the cam but not sure I would know the same question
Old Feb 3, 2006 | 09:18 AM
b20turboic's Avatar
Just put them in ... both will work just fine. The T's just have more lift. But I am not sure what the cams say on them. I havent checked mine for over a year. But either or set will make great power gains over stock and both will be fine for turbo.
Old Feb 3, 2006 | 09:26 AM
ValleySyder's Avatar
Default Re: Question Ls Crower 402t (b20turboic)
on the distbutor side intake cam.. they should be stamped 402-t or 402.. i had a sett of the crower 402 t and they was stamp.. let me know if that helps..
Old Feb 3, 2006 | 10:31 AM
Default Re: Question Ls Crower 402t (ValleySyder)
oh ok i'll check it out thanks guys
Old Feb 4, 2006 | 08:30 AM
they say 402 so does that mean i got screwed and sent NA cams?
Old Feb 4, 2006 | 08:59 AM
non-VTEC's Avatar
you got the N/A cams....but they should still work really well.......
Old Feb 4, 2006 | 10:13 AM
Default Re: Question Ls Crower 402t (non-VTEC)
so what is the big difference
Old Feb 4, 2006 | 01:22 PM
shermanyang's Avatar
here's the difference.
62402-2
Stage 1- Street use and mild nitrous.
Idle to 7250+ rpm. (up to 12 hp).
advertised duration - 259 / 265
Duration @ .50" - 203 / 208
Gross Lift w/1.75 - 417 / 399
62402T-2 Stage 2 - Turbo/Super Charger Special
Specially designed specifically for forced inductionapplications.
Features short duration, high lift for added cylinder pressure and good bottom end power. Requires kit #84162.
Advertised Duration - 270 / 235
Duration @ .50" - 203 / 203
Gross Lift w/1.75 - 469 / 469
ej1b18c1
Feb 17, 2014 03:10 PM
boosted98acura
Feb 4, 2008 10:25 AM
integraboy22
Feb 10, 2007 01:18 PM
SiR HatchAlot
Oct 11, 2003 10:13 PM
xJ.SLOTHx
Jan 24, 2003 05:49 AM
