question on internal wastegate going click.
Old Nov 23, 2007 | 07:37 PM
tr0n9h's Avatar
Default question on internal wastegate going click.
the adjustment bolt from the internal wastegate rod was stuck i think because the threead is either too rusted or mess up. when i try to turn the bolt, the whole rod would move and the bolt would go nowhere. then i hear a sound coming from inside the actuator everytime i try to turn the bolt and the whole rod spin. the sound is a clicking sound everytime i turn the rod.
i was wondering what this sound was and could i mess up the wastegate by trying to lossen the bolt?
also i spend like 30 minute trying to losen the bolt and during this process i dunno how many time i turn it but there were a lot of clicks.
after this incident, the bov start acting up the next few days. it was stop going whooseee and flutter like da da da then 30 minute later it would go whooose again. this is shifting at the same rpm everytime. and now the bov just go da da da and it stop coming back to whooose.
i was wondering did the bov took a crap? or did it have to do something with that clicking sound to cause the bov to be like this?
Modified by tr0n9h at 8:50 PM 11/23/2007
Old Nov 24, 2007 | 12:45 AM
ridin98civic's Avatar
Default Re: question on internal wastegate going click. (tr0n9h)
the click from inside the internal gate was probably the spring spinning. or the rod spinning on the spring. the BOV incident in my opinion is unrelated. take the BOV apart and clean it. it may just be dirty and sticking shut.
Old Nov 24, 2007 | 10:37 AM
tr0n9h's Avatar
o ok, at first i thought the clicking could cause some changes to my air pressure which cause the bov to react different under new pressure.
Old Nov 25, 2007 | 12:27 AM
do you have a boost guage? has your boost changed since you messed with the rod?
Old Nov 25, 2007 | 10:02 AM
tr0n9h's Avatar
Default Re: question on internal wastegate going click. (ridin98civic)
yea the boost is still the same. and is it possible for bov to mess up where you have no way to fix?
Old Nov 25, 2007 | 01:19 PM
Flashmn's Avatar
Yes if you broke the diaphragm. Common problem when using force on the rod.
Old Nov 25, 2007 | 01:54 PM
tr0n9h's Avatar
Default Re: question on internal wastegate going click. (Flashmn)
o i been doing mroe research. i have the turbosmart bov and you have to clean it every so often because it get stuck. im pretty that the problem.
Old Nov 25, 2007 | 02:00 PM
welfarepc's Avatar
the clicking sound you hear might be your internal wastegate flap not sealing 100% with your turbo. i had the same problem when i changed wastegates. to fix it i just installed some washers between the turbo and the wastegate to "lengthen" the push rod and to tighten the wastegate flam to the turbo.
Slappy
Mar 9, 2006 08:23 AM
Drkaccrd
Apr 13, 2005 04:45 AM
ForceFed Coupe
Nov 22, 2004 08:05 PM
FredoSP
Apr 16, 2004 09:41 AM
teg2snbtrbd
Apr 15, 2002 02:36 PM
