question on apexi power fc
well I just bought a 95 integra and it has a power fc ecu, was wondering what I would need to buy to make the ecu use boost and is it a good standalone for 400+ horsepower thanks for the help
1 Post
Intec Racing in Kent WA sells alot of them. They can tune it and make it read boost. And its an AWSOME standalone IMHO. There is so much you can change in the software. Just call up intec and ask them about it.
-Josh who has tuned a couple power FC's
Re: question on apexi power fc (infamousCW-hatch)
you can run up to 10.8psi on the stock map sensor after that you'll need the "D-jetro" kit which is good for 2.5bar.
Apexi part number = 499-X001
1 Post
Re: question on apexi power fc (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">you can run up to 10.8psi on the stock map sensor after that you'll need the "D-jetro" kit which is good for 2.5bar.
Apexi part number = 499-X001</TD></TR></TABLE>
That or you can just use a GM 3 bar map sensor. we have done that a couple times with the fc's flawlessly
u can use any 3 bar map sensor, as long as you calibrate the fc to the sensor readings.
the fc is verry good for boost and can be set to read the 3 bar sensors with no problem.
Re: (infamousCW-hatch)
you will need to recalibrate the fc for the 3 bar map sensor. the only way to do it is to do it via laptop.
I can do it, but you have to bring it by the shop. http://www.intecracing.com
as far as I know, I am the only one with the software to do it, in Wa.
the maps have to be reset to read up to 29 psi boost, and that requires a loptop and software to get into the base program.
Thank God 4 Vtec
06-26-2008 09:40 PM
Civicman86
02-27-2007 03:02 PM
gowyeng
07-08-2004 09:13 AM
