Question about s300 boost control..
Old Apr 21, 2008 | 06:57 PM
TehGhett0P1mp's Avatar
Default Question about s300 boost control..
I know that you need a laptop to control the bosst assuming you have a boost solnoid, but what I am wondering is once you change boost. Do you have to restart the car or anything like that or is everything on the fly? Also is tuning the same as well? If you wanted to change something then would it change real time or do I have to turn the car on and off or something like that for the settings will apply?
Sorry if it has been asked before but I didnt see anyone talking about it and it was something I was wondering as I would like to be able to change boost on the fly either with s300 or with a ebc..
Old Apr 21, 2008 | 07:02 PM
95dc2teg's Avatar
Default Re: Question about s300 boost control.. (TehGhett0P1mp)
you can change the settings in real time, no need to turn the car on and off.
Old Apr 21, 2008 | 07:04 PM
SPOOLINmatt's Avatar
you can change it in real time, while the car is running you can change the boost values or any values and click upload and it uploads it in a blink of an eye. You can change values while tuning and it will use those values, but if you dont upload and you disconnect your laptop, im pretty sure it reverts back to the last previously uploaded map. You don't have to restart the car. Any time you reload a full map file or start fresh, it will take about 5-8 seconds to initially load a map...you have to have the car off for that.
Old Apr 21, 2008 | 07:09 PM
I see well I wanted to be able to just ride around in low boost then have the ability to turn it up if I wanted without having to do anything special, but you guys answered my questions.
Thanks a lot for the quick replys!
Old Apr 21, 2008 | 07:48 PM
Boner_Ben's Avatar
You can have a low/hi switch to switch boost levels on the fly without a laptop.
Old Apr 21, 2008 | 08:41 PM
Default Re: Question about s300 boost control.. (Boner_Ben)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boner_Ben &raquo;</TD></TR><TR><TD CLASS="quote">You can have a low/hi switch to switch boost levels on the fly without a laptop. </TD></TR></TABLE>
How would you go about doing that?
Old Apr 21, 2008 | 08:46 PM
Turbo-charged's Avatar
under your boost control tab
click enable boost control at the top
then click gear based duty cycle
the first drop down menu under gear based duty cycle----click the input you want to use to switch from high boost/low boost
wire up your switch to that input
set up your low boost / high boost tables
and your set
Old Apr 22, 2008 | 04:19 AM
Default Re: Question about s300 boost control.. (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">under your boost control tab
and your set </TD></TR></TABLE>
you can also use the AC button if it works.
Old Apr 22, 2008 | 05:25 AM
Default Re: Question about s300 boost control.. (SPOOLINmatt)
Sweet that sounds pretty simple, when I get everything together I guess ill have to try that. Thanks a lot for the quick replys.
Old Apr 22, 2008 | 06:17 AM
TurboLSVtecTeg's Avatar
You can also run a switch inline too your 12v side of your solenoid and then technically have 3 settings(wastegate, low/high boost settings).
dk=gsr
Engine Management and Tuning
Feb 20, 2012 08:04 PM
Listerofsmeg
Feb 10, 2012 05:16 AM
eflove
Aug 5, 2008 10:04 PM
hyboost
Jul 15, 2008 10:00 AM
TehGhett0P1mp
May 23, 2008 09:20 PM
