Question about nitrous
Old Oct 21, 2004 | 02:45 PM
totsie7944's Avatar
Default Question about nitrous
Could someone please look at my setup in my sig and tell me what you think a 75 shot would do for/against my car. The compression is 12:2:1.
Would it be harmful to my car or would a 50 to a 75 be ok. I asked several mechanics in my area and they said it would probably be ok with that much of a shot.
Old Oct 21, 2004 | 02:47 PM
mrbsponge's Avatar
you should be okay, what injectors do you have, and have you tuned yet?
Old Oct 21, 2004 | 02:49 PM
totsie7944's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">you should be okay, what injectors do you have, and have you tuned yet?</TD></TR></TABLE>
look at my sig, mods are there. but they are 310cc. And the car has been tuned, but I think i may put it back on the dyno soon. It is running a little rich right now.
Old Oct 21, 2004 | 02:57 PM
RyanEJ8's Avatar
Default Re: Question about nitrous (totsie7944)
Make sure to pull at least 4 deg of timing and use 93 octane for that setup.
Old Oct 22, 2004 | 04:40 PM
totsie7944's Avatar
Default Re: Question about nitrous (RyanCivic2000)
Why would i need to do that?
i always use 93 octane....
Old Oct 22, 2004 | 04:47 PM
J337_UNIT's Avatar
pulling timing just helps reduce the change of detonation.. also running colder spark plugs would help
Old Oct 22, 2004 | 04:52 PM
totsie7944's Avatar
Default Re: Question about nitrous (J337_UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">pulling timing just helps reduce the change of detonation.. also running colder spark plugs would help</TD></TR></TABLE>
i have heard that high compression engines run well with n20, is that true?
And also, the has some pre-detonation right now (knocking) if i don;t have it in the right gear for the speed. For instance below 3000 rpms, i can;t floor it in 3rd without some knocking. As for a drag race, there is no pre-ignition because of the strength of my first gear.. Should i worry about anythingt?
Old Oct 22, 2004 | 04:58 PM
b16sedan's Avatar
I wouldn't spray a 12:1 or higher motor on pump gas.
Old Oct 22, 2004 | 05:03 PM
totsie7944's Avatar
Default Re: Question about nitrous (b16coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16coupe &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't spray a 12:1 or higher motor on pump gas.</TD></TR></TABLE>
ok you all have talked me out of nitrous....... there goes my fun for now..... o well i guess next i need fully built turbo engine
B-motor
Nov 8, 2006 09:18 PM
ef8 h0!
Jul 14, 2005 07:22 PM
totsie7944
137
Mar 22, 2005 06:10 PM
RedRocketCRX
Nov 16, 2004 08:04 PM
ninja8oi
Nov 21, 2003 12:53 AM
