Question about coolant loss
Old Sep 10, 2003 | 09:18 PM
vtec.dc2's Avatar
Default Question about coolant loss
If theres coolant loss and no external leaks (this is with new headgasket), oil isn't mixing with coolant, does that eliminate to sleves or cracked cylinder head?
Old Sep 10, 2003 | 09:39 PM
mskibbz-T's Avatar
Default Re: Question about coolant loss (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">If theres coolant loss and no external leaks (this is with new headgasket), oil isn't mixing with coolant, does that eliminate to sleves or cracked cylinder head?</TD></TR></TABLE>
Bump for my own seemingly random coolant loss that occurs very sporadically.
Old Sep 10, 2003 | 09:51 PM
5thgencivic's Avatar
You sure none is being pushed out of the reservoir? Let the car warm up at idle with the radiator cap off and see what happens.. Just my $.02
Nate
Old Sep 10, 2003 | 10:02 PM
vtec.dc2's Avatar
Default Re: Question about coolant loss (5thgencivic)
in one day it went from between min-max to below min.. this is overflow when car is cooled down..
i've had external leak before, which i have fixed, so this had to be internal..
what do i look for when i start car with radiator cap off?
Old Sep 10, 2003 | 10:12 PM
Ri5e's Avatar
look for bubbles
Old Sep 10, 2003 | 10:15 PM
TurboDANDEE's Avatar
Default Re: Question about coolant loss (Tein Man)
mine does the same thing... most likely cause of the GE sleeves
Old Sep 10, 2003 | 11:14 PM
Ray's Avatar
Ray
New User
Default Re: Question about coolant loss (TurboDANDEE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDANDEE &raquo;</TD></TR><TR><TD CLASS="quote">mine does the same thing... most likely cause of the GE sleeves </TD></TR></TABLE>
I have the same thing, im hoping it's something else but...hoping...
Old Sep 11, 2003 | 12:30 PM
vtec.dc2's Avatar
o.k., i tried to do that, and coolant started leaking all over the place as the car kept warming up.. i'm gonna have to come up with a way to make it less of a mess..
also, would doing coolant test damage anything? like make things worse if theres already a leak..
Old Sep 11, 2003 | 01:53 PM
ZygSpeed's Avatar
Me too!
Times like this I wish I'd just gone with a Dart/Payne block!
The oil looks OK though ...??
Old Sep 11, 2003 | 02:04 PM
Default Re: Question about coolant loss (zygspeed)
we should all do a group GE refund
my oil looks fine, but there's traces of oil in my radiator. also, my car cannot take straight driving like an hour straight on the freeway or else it will overheat
Old Sep 11, 2003 | 02:56 PM
Ray's Avatar
Ray
New User
GEM Vince...Where are you???
GEM said they have a new process for their sleeves so they wont sink, what about the people with the old gem sleeves?????
Old Sep 11, 2003 | 03:14 PM
vtec.dc2's Avatar
anyone knows if doing coolant test damage anything? like make things worse if theres a leak to begin with?
Old Sep 12, 2003 | 08:57 AM
Ray's Avatar
Ray
New User
Old Sep 12, 2003 | 09:21 AM
gzrmoto's Avatar
got the same thing with my car magically goes through coolant really slowly never overheats never coolant were it shouldnt be so i just ignore it but keep an eye on it
Old Sep 12, 2003 | 10:07 AM
vtec.dc2's Avatar
Default Re: Question about coolant loss (gzrmoto)
i'm going to do coolant pressure test.. the kit cost $100 from my local auto store, so i gotta find a place to rent one.. basically, its a pump with gauge, goes on top of radiator cap.. then you get it to pressure according to helms manual, and if you see pressure drop.. that means you have a leak, you may also see or hear it..
Old Sep 12, 2003 | 10:22 AM
let us know the outcome
ricerollz
Sep 22, 2010 10:05 AM
SeanK325
Jun 22, 2010 02:52 PM
central_driver
10
Mar 16, 2009 03:48 PM
Razr2
11
Jan 19, 2008 12:50 PM
b00sted4dr
Oct 11, 2006 11:35 AM
