question about a code 3 (map sensor)
Old Feb 20, 2004 | 07:15 PM
b16ahybrid's Avatar
Default question about a code 3 (map sensor)
What are some symptoms of a faulty map sensor? What kind of problems would it cause?
The reason I ask is because my car has been acting up. I will be driving normal and all of a sudden it will die. If i try revving it, then engine sputters and wants to keep trying to die. If i try starting it back up, it will die instantly. When this would occur, i noticed my afr gauge wouldn't light up at all, giving me the clue that maybe it was my o2 sensor..So heeding the advice of a friend i took the o2 sensor out, cleaned it using a lighter then put it back in. Well that seemed to help, the car would then go 15-20 miles between spats (instead of 3-4 miles).
I've tried to pull a code when this happens, but all that happens is the cel stays on constantly (never comes on when its acting up)...
Well i decided to leave the plug jumped while i drove to see what would happen.
Now when the car acts up it isn't as severe (i can keep it going and i am able to accelerate enough to pull over or into a parking lot instead of having to coast). Also while driving I noticed the cel flashing 3......3.......3.......3. So i pulled over, removed the clip, and checked for a code. once again code 3..
So now that i have a code, does this sound like it can be tied together or just coincidence that i got that code?
Btw set-up is as follow
b16a, p-61 ecu turbo stuff
fields sfc, vortec fmu,310cc injectors,trc-1, msd 6-al, ngk plugs, and best of all 5 check valves...
Sorry it's so long, but i wanted to provide as much info as possible. thanks in advance
Old Feb 20, 2004 | 07:19 PM
hondaeg8's Avatar
Default Re: question about a code 3 (b16ahybrid)
sounds like what was happening to my car one time. same code too.
i took the sensor off, cleaned it, put it back on, then it worked fine.
Old Feb 20, 2004 | 07:34 PM
b16ahybrid's Avatar
Default Re: question about a code 3 (stockhatch)
How did you go about cleaning it? Thanks
Old Feb 20, 2004 | 07:49 PM
hondaeg8's Avatar
just took it off the TB and cleaned around it with my hand. make sure the hole isn't clogged up.
thats all i did.
Old Feb 20, 2004 | 07:50 PM
b16ahybrid's Avatar
ok, thanks...
Old Feb 20, 2004 | 09:27 PM
b16ahybrid's Avatar
Anybody else?
Old Feb 21, 2004 | 04:13 AM
turbozc2001's Avatar
check valve problem . i bet thats the problem
Old Feb 21, 2004 | 06:39 AM
b16ahybrid's Avatar
Default Re: question about a code 3 (turbozc2001)
yeah thats what I'm thinking too. The only thing thats throwing me off is that it happens even wen I'm not boosting, but just cruising down the freeway. I did notice that my trc-1 map sensor detects positive pressure under the slightest acceleration
Old Feb 21, 2004 | 07:00 AM
control-alt-delete's Avatar
same problem on my civic. i took off my field's and everything was fine. i personally think that they are junk.
Old Feb 21, 2004 | 10:53 AM
b16ahybrid's Avatar
Default Re: question about a code 3 (1slowhatch)
Yeah it's coming off, but i was hoping to make through this summer before tearing the car apart. I would take it off now and sell it but i have no other way to lean my afr out a little. I'll have to figure something out before next month, thanks for the input..
runderwo
Sep 26, 2011 07:29 AM
Used2beAb16
May 15, 2005 08:12 AM
pinoyboy204
Nov 2, 2003 07:06 PM
