Question about charge pipes
Old Oct 7, 2002 | 02:28 PM
CWBETB's Avatar
Default Question about charge pipes
Hello I have a quick question. How important is to to have the edge lips on a charge pipe? When I say Edge lip I mean the lip that secures the gasket around the pipe. Im just wondering if I will have a problem with leaking air or pipes flying off. Thanks
Old Oct 7, 2002 | 02:42 PM
Etylorcen's Avatar
Default Re: Question about charge pipes (CWBETB)
All the charge pipes are just simple mandrel bent pipes...at least for drag 3 kits. Only the ic has a bump at the end of the pipe. If you tighten down the clamps correctly you shouldnt have to worry about the charge pipes flying off.
bigkvn77
Welding / Fabrication
17
Oct 5, 2008 09:10 PM
number7s
Feb 8, 2005 06:52 PM
tgrace
Aug 22, 2003 09:10 AM
SpeedRacer00-667
May 2, 2002 09:05 PM
