question about boost and ctr and gsr cams
Old Jan 2, 2009 | 04:59 PM
amimaxima's Avatar
Default question about boost and ctr and gsr cams
im asking this for a friend of mine he currently has ctr cams in his motor and he got a set of gsr cams and he was asking me if I knew what was better. ctr intake and gsr exhaust or gsr intake and ctr exhaust. (I didnt know the answer so thats why im posting)
this is his setup
b16a2
endyn 9.5:1 pistons
eagle h beams rods
polished crank
acl race bearings
cometics .030 head gasket
itr valves
itr springs
itr retainers
ctr cams
skunk2 cam gears
skunk2 intake manifold
stock tb
gsr tranny
act clutch
fidanza flywheel
oil catch can
msd 6al box
external ss blaster coil
rc 750cc injectors
greddy type s blow off valve
precision intercooler
turbonetics evolution wastegate
precision sc61
ramhorn manifold
2.5" downpipe
3" exhaust
skunk2 3" muffler
greddy turbo timer
greddy profec b spec II boost controller
autometer 20psi boost gauge
autometer 100 psi oil pressure gauge
no ac
power steering is still on the car
chipped p28 with chrome pro
msd 3 bar map sensor
Old Jan 2, 2009 | 05:01 PM
nonvtecallmotor's Avatar
Default Re: question about boost and ctr and gsr cams
Use both CTR cams.
Old Jan 2, 2009 | 05:11 PM
Italix's Avatar
with that kind of set up I would definitely get a 3" downpipe
Old Jan 3, 2009 | 03:31 PM
Turbo-LS's Avatar
without a 3" dp run both gsr cams. with 3" dp definatly both type r cams
Old Jan 4, 2009 | 02:55 PM
amimaxima's Avatar
im going to change the dp to 3" and retune and I need to figure out which cams to use
Old Jan 4, 2009 | 03:10 PM
supraccordlx's Avatar
Use the ctr cams, much better then gsr.
Old Jan 4, 2009 | 03:26 PM
turbociv910's Avatar
type r cams best OEM cam for boost
Old Jan 4, 2009 | 03:36 PM
quicksilver1689's Avatar
i ♥ snails
meh both are fine, you can make over 600whp with both
Old Jan 4, 2009 | 04:16 PM
blinx9900's Avatar
wow, whats up with people trying to missmatch cams, its just retarted, this was done back in the day only because cams where so expensive and cheap *** people were being ghetto, THERE IS NO REASON TO MISSMATCH CAMS, ITS 2009 FOR GOD SAKE!
but to answer your lame easily searchable question use CTR both.
Old Jan 4, 2009 | 04:24 PM
i ♥ snails
whats wrong with ctr intake, gsr exhaust theres not a whole lot of difference on the exhaust side is there? its been awaile since ive looked at the profile specs
Old Jan 4, 2009 | 04:48 PM
blinx9900's Avatar
Dur @ .050
GSR 230°/216°
CTR 233°/224°
Old Jan 4, 2009 | 06:13 PM
i would like a gsr cam then, shorter overlap with minimal valve lift changes
Old Jan 4, 2009 | 08:32 PM
blinx9900's Avatar
its your car, do as you like...
Old Jan 4, 2009 | 08:39 PM
AR Performance's Avatar
i made 800hp with ctr cams
Old Jan 4, 2009 | 08:40 PM
gsr exhaust sorry, ctr intake
Old Jan 4, 2009 | 08:52 PM
blinx9900's Avatar
once again, its your car, do as you wish... both cams are proven, one is proven to make more than the other but if you think you know some better way go for it...
A.R
Aug 3, 2012 01:15 PM
turbo boost
Mar 10, 2006 10:15 AM
AllMotor12s
10
Jun 27, 2004 07:50 PM
sihatchyvtec
Sep 25, 2003 08:22 AM
TEGPOWER44
Dec 12, 2002 06:11 PM
