ctr cams good with boost?
Old Mar 4, 2006 | 08:49 AM
turbo boost's Avatar
Default ctr cams good with boost?
will ctr cams still be good with boost..or would stock b16 cams be better?
Old Mar 4, 2006 | 08:51 AM
b18c5hatchie
Guest
Posts: n/a
Default Re: ctr cams good with boost? (snowbunny)
ctr
Old Mar 4, 2006 | 09:12 AM
Default Re: ctr cams good with boost? (b18c5hatchie)
kool
Old Mar 4, 2006 | 09:38 AM
GS-R Civic's Avatar
how about ctr vs gsr cams, is it worth the upgrade?
Old Mar 5, 2006 | 07:19 AM
Default Re: ctr cams good with boost? (GS-R Civic)
anbody??
Old Mar 7, 2006 | 05:09 AM
GS-R Civic's Avatar
bump
Old Mar 7, 2006 | 05:22 AM
sp00led's Avatar
ctr/itr + boost = big numbers
I don't have dyno charts handy but if you search around there are plenty of gsr vs ctr/itr cams examples to be found.
Old Mar 7, 2006 | 08:13 AM
rondigs's Avatar
Default Re: ctr cams good with boost? (sp00led)
I made an additional 50hp switching from GSR to ITR cams. Same boost level (pump gas).
Old Mar 7, 2006 | 08:23 AM
tony1's Avatar
Default Re: ctr cams good with boost? (rondigs)
You had a better tuner this time though, your results don't count.
Old Mar 7, 2006 | 09:35 AM
rondigs's Avatar
Default Re: ctr cams good with boost? (tony1)
Everybody bow to Tony. He's feeling down and needs an ego boost.
Old Mar 7, 2006 | 09:39 AM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">how about ctr vs gsr cams, is it worth the upgrade?</TD></TR></TABLE>
if you have the extra change buy a set of itr/ctr cams. if not then keep the gsr...ive seen 800+whp on gsr cams.
Old Mar 7, 2006 | 11:18 AM
GS-R Civic's Avatar
Default Re: ctr cams good with boost? (gt42r_civic)
Any major gains on a low boost application 7psi?
I made 272whp at 7psi on a stock gsr, just looking for a few things that could get me close to 300!
Old Mar 7, 2006 | 11:30 AM
is adj cam gears a must wit ctr cams and boost??will much be gained? wit adj cam timing??
Old Mar 7, 2006 | 01:05 PM
Silverhatch's Avatar
i want a set but I cant find them anywhere.
Old Mar 7, 2006 | 01:32 PM
miyagi's Avatar
icbmotorsport/jdmland sells brand new CTR intake cams ... not sure about exhaust.... you can find them on ebay now and again.
Also - if i'm not mistaken, blox/skunk2 stage 1's are basically a 98+ ITR/CTR cam grind.
Old Mar 7, 2006 | 05:26 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS-R Civic &raquo;</TD></TR><TR><TD CLASS="quote">Any major gains on a low boost application 7psi?
I made 272whp at 7psi on a stock gsr, just looking for a few things that could get me close to 300!</TD></TR></TABLE>
turn the boost on up...also tune it of course...lol. 300whp easy.
Old Mar 7, 2006 | 05:30 PM
MrParks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowbunny &raquo;</TD></TR><TR><TD CLASS="quote">will ctr cams still be good with boost..or would stock b16 cams be better?</TD></TR></TABLE>
why spend money on ctr cams when you can get off the shelf turbo cams from comp cams. they made 50+ more then the ctrs i had on just the change out itself and i picked them up for 450 huge power gains across the board from 5500rpm +
Old Mar 7, 2006 | 06:02 PM
Default Re: ctr cams good with boost? (GHOSTWORKS)
im not goin to spend the money..lol its already spent..i allready got the ctr cams in my lsvtec....but im soon gona be boostin it..and just want to no if they work wit boost or not...but my question was anwsered ...thanks
Old Mar 7, 2006 | 06:22 PM
4rc-fed's Avatar
Turbo cams suck ***
Old Mar 8, 2006 | 04:58 AM
GS-R Civic's Avatar
Default Re: ctr cams good with boost? (4rc-fed)
So ctr intake cam and gsr exhuast cam,
or ctr intake and exhuast cams over gsr cams
Old Mar 8, 2006 | 11:26 AM
burnt_rice's Avatar
ctr intake cams are great and the type r and ctr exahaust cams are the same in duration it's better to have one ctr cam (intake side) and either ctr or type r (exhaust side)
Old Mar 8, 2006 | 01:33 PM
GS-R Civic's Avatar
Default Re: (burnt_rice)
alright sounds good...
Old Mar 8, 2006 | 02:21 PM
MrParks's Avatar
how you figure? let me know... 610 to 660hp sux,then i should just put my ctrs back in..
Old Mar 8, 2006 | 02:45 PM
GS-R Civic's Avatar
huh?
Can anyone verify if Blox cams are the same was CTR cams?
Old Mar 8, 2006 | 03:53 PM
beerbongskickass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GHOSTWORKS &raquo;</TD></TR><TR><TD CLASS="quote">
why spend money on ctr cams when you can get off the shelf turbo cams from comp cams. they made 50+ more then the ctrs i had on just the change out itself and i picked them up for 450 huge power gains across the board from 5500rpm +</TD></TR></TABLE>
Maybe with your setup it was a little different, but from what I have read ITR/CTR or GSR cams are what you want on a honda motor. Certain turbos cams will just get you less power. Plenty of people have made 500+whp with OEM cams and there have been a few that made 800+whp I believe, so they are defintely capable.
Here is a good thread to check out... http://forums.evans-tuning.com...=1623
