Question about 1000cc injectors?
Old May 27, 2006 | 02:26 AM
jep's Avatar
jep
Default Question about 1000cc injectors?
How much WHP can 1000cc injectors support on a fully built b18c, 9:1 C/R with a T3/T67?
Im thinking bout re tuning and wondering if I should get bigger injectors. Im making 425whp @ 15psi currently. I want 600WHP
Old May 27, 2006 | 05:14 AM
Turbocivic94's Avatar
Default Re: Question about 1000cc injectors? (jep)
1000cc should be good for 600whp
if u want more than that I would go with 1600cc
Old May 27, 2006 | 08:26 AM
morgan@synapse motorsport's Avatar
u have a t3/t67 and u only pushed it to 15psi?
u can make upwards of 700whp with a good fuel system, the most i would push it with a walbro would be like 600whp, but if u had a good system that can support higher pressure max that turbo out
Old May 27, 2006 | 07:52 PM
jep's Avatar
jep
well I have never driven a car this powerful b4 so I am now getting familiar with how this car behaves. 15psi on this thing is scary...lol. well at least for me...lol. I have Aeromotive A1000 fuel pump, all steel braided lines, holley fpr, STR fuel rail and venom 1000cc so i guess that should be okay for 600whp.
I also wanna hook up some sort of direct port water/alcohol injection.
Old May 27, 2006 | 10:43 PM
714phil's Avatar
Default Re: (jep)
610whp: Fuel system consisted of 255lph intank, RC 1000cc injectors(peak & hold). Everything else that had to do with the fuel system was factory.
Old May 28, 2006 | 07:31 PM
jep's Avatar
jep
Default Re: (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">610whp: Fuel system consisted of 255lph intank, RC 1000cc injectors(peak & hold). Everything else that had to do with the fuel system was factory. </TD></TR></TABLE>
wow, thats impressive. even fpr was stock? what was your fuel pressure at?
Old May 28, 2006 | 07:54 PM
714phil's Avatar
Default Re: (jep)
yes stock fpr. I didnt have a gauge so i couldnt really tell you what it was at. probably maxing out the injectors though..
Old May 28, 2006 | 09:11 PM
eg:R's Avatar
how come i only dyno my car at 400hp and my tuner said that my injectors are already max out. the duty cycle were around 90's. i'm running 255lph intank with 1000cc injectors(p/h) on stock fpr on hondata. i want more boost
Old May 28, 2006 | 11:32 PM
vaporboy12's Avatar
Default Re: (eg:R)
becasue you need more base fuel pressure
Old May 29, 2006 | 01:50 AM
eg:R's Avatar
what do u mean?
Old May 29, 2006 | 08:37 AM
raene's Avatar
Default Re: (eg:R)
He means turn up the fuel pressure. If you're only pushing 30psi at the rail you'll get a lot less fuel than at 50psi. Or maybe you're asking the rail to flow too much, just another thought.
Old May 29, 2006 | 10:25 AM
eg:R's Avatar
my guage show 45psi
Old May 29, 2006 | 10:47 AM
raene's Avatar
Default Re: (eg:R)
Maybe you're running out of flow through the rail then.
Old May 29, 2006 | 10:54 AM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jep &raquo;</TD></TR><TR><TD CLASS="quote">How much WHP can 1000cc injectors support on a fully built b18c, 9:1 C/R with a T3/T67?
Im thinking bout re tuning and wondering if I should get bigger injectors. Im making 425whp @ 15psi currently. I want 600WHP </TD></TR></TABLE>
What's your duty cycle at now with those injectors?
range hadies
Apr 2, 2012 08:02 AM
onelowchef
May 29, 2004 04:23 AM
NyQuiL
Jul 7, 2003 05:44 PM
simple4012
Aug 23, 2002 08:35 PM
Malice
Jun 7, 2002 11:31 AM
