Q. about vortech aftercooler
Old Jan 12, 2004 | 04:00 PM
_jester_'s Avatar
Default Q. about vortech aftercooler
How much power can you put through these on a daily driver? Or would this be variable pending waterflow?
Old Jan 12, 2004 | 08:54 PM
xxxmikenicexxx's Avatar
Default Re: Q. about vortech aftercooler (XratedSi)
Yes, its variable pending waterflow and water temp
Old Jan 12, 2004 | 10:54 PM
ClubSiRacer's Avatar
Well assuming the stock aftercooler with a small heat exchanger in the front and a small tank somewhere, probably 400ish for normal use. With a bigger heat exchanger and larger tank or even iced water you can run a lot of power through it. I dont have a pic i can link now but a friend built a custom ice chiller for his Vortech that uses a fuel chiller from Moroso and runs the liquid through the lines made for fuel which passes through a coil submerged in ice/water. It works extremely well...
B18c1turboedEK
Jan 24, 2011 02:38 PM
c5R
Welding / Fabrication
23
Feb 23, 2010 05:49 PM
TurboMiata
Oct 27, 2004 11:04 AM
boosted hybrid
Dec 3, 2002 10:35 AM
comptechgsr
Sep 20, 2002 11:51 AM
