PVC for Catch Can
Old Dec 12, 2004 | 09:29 PM
oxSLEEPERxo's Avatar
Default PVC for Catch Can
for d16z6, do you have to buy a new pvc fitting?(i attached a pic of it) or can you just use the stock pvc fitting and and stick the hose on there?
Old Dec 12, 2004 | 09:53 PM
Bailhatch's Avatar
Default Re: PVC for Catch Can (oxSLEEPERxo)
Positive Crankcase Ventilation
Old Dec 12, 2004 | 09:56 PM
liquidxEG's Avatar
Default Re: PVC for Catch Can (Bailhatch)
lol when i read the title, i thought he wanted to use a piece of PVC piping for a catch can
Old Dec 12, 2004 | 10:03 PM
SHystrdyGSRtdy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">for d16z6, do you have to buy a new pvc fitting?(i attached a pic of it) or can you just use the stock pvc fitting and and stick the hose on there?
<FONT SIZE="10">THIS IS FOR A B-SERIES MOTOR, NOT D-SERIES</FONT>
those are for the back of the block....
green lines
Modified by SHystrdyGSRtdy at 10:36 PM 12/13/2004
Old Dec 12, 2004 | 11:52 PM
500hpsi's Avatar
Default Re: PVC for Catch Can (SHystrdyGSRtdy)
Stupid question, but will those fitting fit in place of allen plug here the two green line point to? and it that Honda parts? and those are the Honda part number right?
thanks
Old Dec 13, 2004 | 05:07 AM
USDM 4G VTEC's Avatar
the ^^^^^^ picture is a B series engine
its not a D series...
be careful and dont get people confused, since one of the green plugs on the left on the D series is a water jacket, u dont want someone to screw up or make a thread asking why they got water out of it
Basically u need a line from back of block into the catch can, another hose from valve cover to catch can, , and the catch cant with a filter vented to atmosphere
Old Dec 13, 2004 | 05:57 AM
Default Re: (USDM 4G VTEC)
so people with d16z6, yall didn't have to buy a one of those fitting right. For B series motor, yall have to buy those fitting right. The reason why i asked is that endyn gives you one of those fitting. BTW this catchcan will be used on a turbo'd motor
I am doing it this way:
Modified by oxSLEEPERxo at 12:26 AM 12/14/2004
Old Dec 13, 2004 | 08:26 PM
Default Re: (oxSLEEPERxo)
[QUOTE=oxSLEEPERxo]so people with d16z6, yall didn't have to buy a one of those fitting right. For B series motor, yall have to buy those fitting right. The reason why i asked is that endyn gives you one of those fitting. BTW this catchcan will be used on a turbo'd motor
Old Dec 13, 2004 | 09:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">the ^^^^^^ picture is a B series engine
Basically u need a line from back of block into the catch can, another hose from valve cover to catch can, , and the catch cant with a filter vented to atmosphere</TD></TR></TABLE>
oh damn, my fault, i didn't catch the part where he said it's for a d16... i'll edit it
Old Dec 13, 2004 | 10:11 PM
CivicEJ1's Avatar
This my setup.....works get...
Before I did this there would be oil leaking from my valve cover gasket and you can tell there is pressure in the valve cover....at that time it just had a breather air filter...
Now that I did this I have not seen a drop of oil leaking from my valve cover gasket...I used clear piping so if anything but air is sucked I would know. For precaution I used a fuel filter in the middle of the line to prevent gunk & oil vapor from being sucked into my turbo...
Old Dec 14, 2004 | 06:44 AM
Boofster's Avatar
Default Re: (CivicEJ1)
Old Dec 14, 2004 | 07:35 AM
turbosi03's Avatar
Default Re: (Boofster)
how many of you guys are using the anti siphen fittings like endyne sells?
Old Dec 14, 2004 | 09:06 AM
ladysman's Avatar
Default Re: (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">how many of you guys are using the anti siphen fittings like endyne sells?</TD></TR></TABLE>
According to Endyn (larry) the anti-siphon tubes are ONLY used for the B series motors in his builds. D and H series will use the fitting on the right only on both sides of the block.
The fittings much be machined and tapped in the block for D series.
Old Dec 14, 2004 | 12:45 PM
Default Re: (ladysman)
anyone here with a dseries running a catch can other than tapping the block? if you are, can you explain how you did it, thanks
one-cam
Jul 30, 2008 05:16 PM
INVALID
30
Sep 24, 2006 10:36 PM
Syndacate
15
Feb 10, 2006 08:19 AM
nekoabandoned
13
Dec 2, 2005 10:05 PM
ablack934doorcivic
Sep 12, 2004 05:44 PM
