Putting vacuum lines into your car for a Boost controller
Old Jan 27, 2002 | 08:29 AM
Ri5e's Avatar
Default Putting vacuum lines into your car for a Boost controller
Currently my boost controller is under my hood for quite some time. But now I want to put it in my car, but I'm afraid that running vacuum lines that long will make it less effective. Anyone ever try this?
Old Jan 27, 2002 | 01:13 PM
Ri5e's Avatar
Default Re: Putting vacuum lines into your car for a Boost controller (BG Boost)
Up you go. Also, Did you have to drill holes to run the lines through? If so, please tell me/post pics of where you sent the lines
Old Jan 27, 2002 | 03:18 PM
maxim's Avatar
I don't know the exact layout of the teg chassis, but with my civic I found one small hole and one larger hole(covered with black plastic plugs) on the driverside firewall. There is a fuzzy soft material that you must breakthrough(with a screwdriver) to get to the other side and then you can route the line in back of the dash or wherever up to the controller. I don't know if you have tried this yet or have anything else going into those holes, but the larger hole should work perfectly. What controller do you have anyway? A Turboxs?
Old Jan 27, 2002 | 07:36 PM
Ri5e's Avatar
Default Re: Putting vacuum lines into your car for a Boost controller (maxim)
I have a turbonetics. Today, I just drilled two holes, right on top of the BIG hole with black rubber on the driver side.
I ran the vacuum lines through, but haven't ocnnected the boost controller yet.
Just*Hatched
Mar 6, 2014 07:00 PM
bads2k
Nov 26, 2009 01:38 PM
99delsol
Sep 16, 2006 01:44 PM
FyReo3
Aug 6, 2005 04:35 PM
ebpcivicsi1234
Feb 11, 2005 06:12 AM
