Putt Putt, Hesitation, almost like backfiring under boost....
Old Jan 22, 2004 | 08:21 PM
MikeMAN's Avatar
Default Putt Putt, Hesitation, almost like backfiring under boost....
Hey All..
I have had my greddy kit installed for about 2 weeks. The First week I had it I didn't have the following problem, which leads me to believe it is the weather.
Setup:
Greddy SOHC Kit with Blue Box
Greddy EVO Cat-Back
Problem:
In 2nd gear when i get on it, around 5500+ rpms i get a couple hesitations like it is backfiring, doesn't sound like detonation at all..NO pinging..
also, I am now making .5 bar of boost, is this because of the colder weather + denser air?
Thanks for tall the help!
Mike
Old Jan 22, 2004 | 10:21 PM
Speedworks801's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (MikeMAN)
You will rarely hear pinging on a turbo honda, it's a lot easier with a supercharger. If you are experience something similar to backfiring, that is generally a lean condition that causes a popping sound. If you are experiencing a hesitation without popping, that is generally too rich. Read your plugs if you are not taking your car to get tuned. I recommend tuning as the best money spent on your car.
Good Luck
Old Jan 22, 2004 | 10:29 PM
Mase's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (Speedworks801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedworks801 &raquo;</TD></TR><TR><TD CLASS="quote">You will rarely hear pinging on a turbo honda, it's a lot easier with a supercharger. If you are experience something similar to backfiring, that is generally a lean condition that causes a popping sound. If you are experiencing a hesitation without popping, that is generally too rich. Read your plugs if you are not taking your car to get tuned. I recommend tuning as the best money spent on your car.
Good Luck </TD></TR></TABLE>
woot, i like what i hear.
Old Jan 22, 2004 | 10:42 PM
Kataku2K3's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (Mase)
This normally only happens when running higher boost but what kind of plug gap are you running... Even with aftermarket ignitions we were blowing out the spark with Brian's car running 24lbs. and a 0.028" gap... Took it down to 0.024-0.026" and everything was fine... Definately go with what Speedworks said and read your plugs, Good Luck
Old Jan 25, 2004 | 10:27 AM
MikeMAN's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (Kataku2K3)
thanks fellas, im running stock boost and stock blue box (and this didn't happen in mild weather) so I am still totally puzzled, could this be gap then? I will pull the plugs and check em out..
mike
Old Jan 28, 2004 | 09:20 PM
MikeMAN's Avatar
anyone else? i would pull the plugs but it is WAYYY too cold out right now hahaha
mike
Old Jan 28, 2004 | 09:53 PM
PrecisionH23a's Avatar
If you do not have your plugs gapped to .030ish then you will blow out your spark when you hit 4 or so psi. I recommend running the NGK BCPR7ES (part number 3330).
Old Jan 29, 2004 | 05:51 PM
MikeMAN's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">If you do not have your plugs gapped to .030ish then you will blow out your spark when you hit 4 or so psi. I recommend running the NGK BCPR7ES (part number 3330).</TD></TR></TABLE>
i don't think that is necessarily true running this low of boost, i have NEVER seen it happen at super low boost before. However, on another note..my car IS now detonating..it seems to be going with a correlation of how cold the weather is. (-33 degrees today with windchill)
mike
Old Jan 29, 2004 | 06:00 PM
ntegls's Avatar
True, ever since the weather has gotten colder, temps on my egt gauge indicates
a leaner ratio.
Old Jan 29, 2004 | 09:31 PM
MikeMAN's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (ntegls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ntegls &raquo;</TD></TR><TR><TD CLASS="quote">True, ever since the weather has gotten colder, temps on my egt gauge indicates
a leaner ratio.</TD></TR></TABLE>
goddamn't...i wanna beat the **** outta my car now!!! I WANT TO ACCELERATE 100% throttle haha
mike
Old Jan 29, 2004 | 10:29 PM
ClubSiRacer's Avatar
I run the same plugs at 0.032 at 15psi with no problems at all... So your theory isnt necessarly correct. But those plugs work nicely however. I buy them 2 boxes at a time and change them as necessary.
Old Jan 29, 2004 | 10:44 PM
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (ClubSiRacer)
I guess my statement misled you guys. I originally intended to say that if you have your plugs gapped at the STOCK GAP then under boost you will misfire becuase the boost will blow out your spark. And by the way, i said .030ish ish meaning give or take .002
If you don't believe me, go outside, gap your plugs to a .044 and tell me what happenes around 4-5k rpms
Old Jan 30, 2004 | 08:02 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I guess my statement misled you guys. I originally intended to say that if you have your plugs gapped at the STOCK GAP then under boost you will misfire becuase the boost will blow out your spark. And by the way, i said .030ish ish meaning give or take .002
If you don't believe me, go outside, gap your plugs to a .044 and tell me what happenes around 4-5k rpms </TD></TR></TABLE>
appreciate ur help bud, i will try it...its -40 with windchill now so im ******* detonating...goddamnt...BE WARMMM!!!!
mike
Old Jan 30, 2004 | 09:28 AM
Johnyquest's Avatar
Cold air should help to STOP detonation... Unless your going lean. Retard your timing two degrees or so, and close the gap up on your plugs. It might be time for some new cap / rotor / wires.
Good luck.
Old Jan 30, 2004 | 09:37 AM
rtype11's Avatar
if youre afraid of blowing the spark out, get these:
they do get fouled easy though if you run rich in vacuum, they are also cleanable (sandblasting etc... several times)
Old Jan 30, 2004 | 08:07 PM
MikeMAN's Avatar
Default Re: Putt Putt, Hesitation, almost like backfiring under boost.... (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">Cold air should help to STOP detonation... Unless your going lean. Retard your timing two degrees or so, and close the gap up on your plugs. It might be time for some new cap / rotor / wires.
Good luck.</TD></TR></TABLE>
as you can see, my setup im running stock boost and greddy blue box..
however, with really cold weather...air is more dense, more air + same amount of fuel = leaner....
mike
Old Jan 31, 2004 | 11:20 AM
MikeMAN's Avatar
anyone else with insight as to why NOW im detonating? is it REALLY the cold weather? it makes sense to me, cause im boosting .5 bar now cause the air is sooo dense.
mike
Old Feb 10, 2004 | 05:23 PM
MikeMAN's Avatar
mwahaha...problem solved....took out plugs and checked what they were previously gapped at.... .065"!!!!!!!!!!!!!!! thats way outta even STOCK spec!
bought new plugs, gapped at .030 voila..not detonation..no funny hesitiation..thing just rips!
mike
xiLLtegRax
Mar 9, 2008 05:47 PM
conceptEG
14
Apr 17, 2006 07:38 PM
ktran1
Apr 20, 2004 10:01 PM
VspecSiR
Mar 25, 2004 01:50 PM
PSIKOTICcrx
Mar 28, 2003 03:35 PM
