Pushing the set-up
O Reery?
OP: 380+ on 11lbs on that set-up, thats awesome IMO.
Derrick: I made the same numbers (with a **** hair more trq) with 3-4lbs more. other than the .5 over bore and valvetrain. what else is factoring those numbers, or do those components make that much of a difference?
Originally Posted by mar778c
Block- B18C1, OEM gsr crank + rods, 81.5 mm RS machine pistons (PTW 0.002" for all cylinders), OEM main bearings (bearing clearance 0.0018" for all bearings), and ACL rod bearings (bearing clearance 0.0018" for all bearings)
Everything bolded plus a very good machinist.
Ya gat dat right. :p
And I look forward to seeing this again, Marcell. I will most likely be at the shop that day. You bringing the Wes-man again, too?
Definitely from the cam setup. And it's only like a 4% drop in torque through that region. Hardly noticeable with a power-to-weight like that, especially in the lower gears where traction is more of an issue - hell, it'll be impossible to notice given wheel spin and where the trans will drop the RPM back to on shifts.
Lookin good as always guys.
Congrats Marcell!
I guess what we have all learned from the previous posts, is if you don't what you are talking about, keep your hands off the keyboard. Nothing kills a reputation more than assumptions and statements with no valid arguments.
Now lets get back to the awesomeness
^^^I had a minor set back.
After getting everything set-up. The 1st few pulls looked very promising. It made more torque and built boost approximately 500 prm quicker using e85 at the same level of boost, 11.2 lbs. However, we could not go any further because the clutch was slipping. So, in a couple of weeks hopefully I will have this remedied and we can proceed with making more power.
Good news: the set-up and e85 will definitely make 450+ whp with maybe 3 to 4 lbs more boost.
Bad news: I have to get a new clutch to get done.
Also, my tuner (D-rob) will limit the set-up in terms of torque because the block is only using stock rods and cast pistons.
awsome #'s for such a simple build.
Kinda crazy, bc I'm almost done making my own turbo kit for my 200hp 11:1 comp gsr motor with skunk2 tuner2 cams using a billet 6262. Can't wait to see how it compairs to your build.
That sounds like a helluva street build. Start a thread. I would definitely like to see how it turns out.
