Purchasing T3, need help identifying problems
Old Apr 29, 2006 | 11:50 AM
Schurke's Avatar
Default Purchasing T3, need help identifying problems
So I'm about to go check out a partial turbo setup which includes a T3 (from a 300ZX), exhaust manifold (with wastegate) for b-series and some other misc parts (no details yet). I am concerned about the T3 (with no rebuild) having leaks or other problems, as well as the manifold on it's verge to having damage? If you have any advice on what problems to look for with the T3, manifold, bov, wastegate... and how to identify them. Your information and advice will save me a few hundred so I really appreciate it.
PS. I will also take pictures of the setup when I go see it.
Old Apr 29, 2006 | 12:52 PM
Circuit Star-29's Avatar
Default Re: Purchasing T3, need help identifying problems (Schurke)
Look for cracks in the manifold...Turbine shaft play, there will be some but if its more then a couple mm then it may need a rebuild.
Old Apr 29, 2006 | 01:58 PM
Schurke's Avatar
Default Re: Purchasing T3, need help identifying problems (Circuit Star-29)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circuit Star-29 &raquo;</TD></TR><TR><TD CLASS="quote">Look for cracks in the manifold...Turbine shaft play, there will be some but if its more then a couple mm then it may need a rebuild.</TD></TR></TABLE>
So I just play around with the turbine using my finger to see how much it moves in and out? What is an acceptable amount, that you personaly would be fine with (mm)?
Old Apr 29, 2006 | 05:09 PM
N20civicB18's Avatar
if there is a couple mm of shaft play dont even consider getting it
Old Apr 29, 2006 | 05:22 PM
fieromadman's Avatar
Default Re: Purchasing T3, need help identifying problems (N20civicB18)
i got a t3 a/r 48 for sale 200 obo it was rebuild there is no shaft play!
Old Apr 29, 2006 | 07:19 PM
Schurke's Avatar
Default Re: Purchasing T3, need help identifying problems (fieromadman)
Too bad I got the whole setup for 300 dollars CND (excluding intercooler, injectors, lines)...
HamiltonRex
Dec 24, 2008 07:39 PM
mrbig
Jun 4, 2008 10:37 AM
97CWITR
Aug 31, 2007 06:46 PM
Everyones Hero
Oct 25, 2006 07:28 AM
Flamenco-T
Jul 20, 2002 03:48 AM
