Pump relay trigger wire
Old Jul 24, 2014 | 06:11 PM
boostlsveg's Avatar
Default Pump relay trigger wire
Hi guys. My car is close to finished so now I need to finish wiring the 50 amp for my pumps. My question is could anybody tell me which wire in this plug I should use to trigger the relay? I tried using a multimeter from the ecu pin but did not get signal from either pin. I believe the battery may need to b in for the relay to trigger n the wire to get signal. But I still need to finish some wiring before I can put the battery in. Thanks mike
Old Jul 24, 2014 | 06:49 PM
turbohatch96y7's Avatar
Default Re: Pump relay trigger wire
Yellow green is the power to the fuel pump assuming this is 96 plus
Ecu sends ground signal to main relay, relay gives voltage to fuel pump. fuel pump is grounded to chassis.
you can use the ground from the ecu (a16) to your relay. Actually that's the only way since the point is to draw more current to the pumps.
Old Jul 24, 2014 | 06:53 PM
wantboost's Avatar
Who is Mr Robot?
ummmm yea... no battery = no current, no current = no signal.
Old Jul 25, 2014 | 09:53 AM
boostlsveg's Avatar
Originally Posted by turbohatch96y7
Yellow green is the power to the fuel pump assuming this is 96 plus Ecu sends ground signal to main relay, relay gives voltage to fuel pump. fuel pump is grounded to chassis. you can use the ground from the ecu (a16) to your relay. Actually that's the only way since the point is to draw more current to the pumps.
it's a 92. I'm just using this wire to trigger the relay. I have 8awg run to the relay itself. Thanks for the help.
Wantboost-I figured since there was a relay the car had to have power. If there wasn't a relay in between u can check for continuity from the pin to the plug in the back, without power, which is what I was trying to do.
Old Jul 25, 2014 | 10:16 AM
Let us know how it goes.
Where did you get the relay from? Are you putting a fuse inline?
Old Jul 25, 2014 | 06:25 PM
boostlsveg's Avatar
Let us know how it goes. Where did you get the relay from? Are you putting a fuse inline?
I got the relay from my local shop. Standard 50 amp relay. And yes 50 amp fuse inline.
Jamesb223
Jan 21, 2018 08:01 PM
Lmgrcivic
Apr 7, 2010 01:30 PM
Bond
Oct 5, 2009 05:37 PM
tegdude227
Jan 31, 2009 03:59 PM
RACEPAK
Feb 10, 2008 10:58 AM
