pump failure....
Old May 25, 2004 | 08:05 PM
scatuli's Avatar
Default pump failure....
ok i start my car it idles for about 2 seconds shuts off wont start. i am getting spark, i noticed the fuel pressure on my fuel gauge wasnt going up at all, i couldnt hear the pump prime when the key turned the ignition on, so i tapped it with a hammer and then it started. i drove home parlked it and orded a new walbro 255
now for my question; i am running 550cc injectors at 10psi uberdata. first and second gear pull pretty hard but then third and fourth feel kinda weak. would it be possible that the stock pump couldnt keep up and eventualyy it killed the pump?
thanks
Old May 26, 2004 | 03:53 AM
scatuli's Avatar
Default Re: pump failure.... (scatuli)
anyone have any thoughts?
Old May 26, 2004 | 04:17 AM
ATS*Mark's Avatar
OG triple OG
you were probably leaning out due to having a stock pump , but no one can say for sure , you got the walbro on the way so problem solved . and you WILL hear the walbro prime
Old May 26, 2004 | 01:17 PM
darylfiend11's Avatar
Default Re: pump failure.... (Hella_JDM)
ha yeah i hear they are loud but thats ok and for me using a basemap my plugs looked pretty good so who knows i will let everyone know.
by the way im on my buddies name
Old May 26, 2004 | 02:01 PM
b18cx's Avatar
Default Re: pump failure.... (darylfiend11)
A whalbro is not loud. Now, an Aeromotive A1000 is loud.
Old May 26, 2004 | 02:16 PM
ATS*Mark's Avatar
OG triple OG
Default Re: pump failure.... (b18cx)
ya they are loud , but walbros whine from under the seat and all that ****.
but aeromotive a1000's are ******* loud ahah
Old May 26, 2004 | 02:23 PM
Turbo E's Avatar
Dynamat pwnz j00
Old May 27, 2004 | 03:48 PM
scatuli's Avatar
Default Re: (Turbo E 604)
does anyone know where i can get the bolts that go on the gas tank strap, the ones i have are all rusted. the local dealer have them for 9 bucks any suggestions?
Old May 27, 2004 | 09:02 PM
scatuli's Avatar
Default Re: (scatuli)
well i got it all done, and i htink the 255 helps out from what i noticed tonight. The only wierd thing i noticed was that the stock pump from the b18a1 was larger in size than the 255 walbro, has anyone else noticed that? but now my clutch slips hardcore!
Boognish
Jul 24, 2005 06:03 PM
TurblowR
Jun 23, 2004 09:28 AM
Kutsuju_SLeePER
Oct 29, 2003 01:34 AM
preluder
Aug 29, 2003 07:56 AM
YellowR2000x2
Jan 5, 2003 07:31 PM
