Puff of smoke
Old May 13, 2016 | 04:42 PM
prezioso01's Avatar
Default Puff of smoke
I'm getting a decent puff of smoke white/blue with a oil burning smell along with it only after a hard pull
Does not smoke under normal driving conditions
Does not.smoke when in 2 step
Does not smoke.on idle nor cold starts
Not a drop has moved on the dip stick after some steady driving
Tuned b18b precision 5858 750cc fic
I do have a go.autoworks mini ram sits pretty low I have restricted the oil feed not sure if it's my drains but I'm not ruling it out either
I do run a pretty thick oil but when she gets hot it needs it 15/50 redline
Any ideas where to start... leak down ? Valve seals ?
I check my.plugs today and in the cylinder where the valve cover meets was a lil greasy valve cover no goood? I just don't see that causing a puff after hard pulls ? Running out of ideas going to try a new oil drain next weekend? Anything at all will help appreciate it
Old May 13, 2016 | 04:43 PM
prezioso01's Avatar
Default Re: Puff of smoke
Old May 13, 2016 | 04:45 PM
prezioso01's Avatar
Turbo is brand new not even 200 kms on it
Old May 13, 2016 | 04:49 PM
2kdrift's Avatar
pics with fingers blocking plates is now on H-T
wat a sad day
Old May 13, 2016 | 04:52 PM
prezioso01's Avatar
Sorry? These car get stolen alot not tryna have my **** jacked cause I needed some info the net sorry to.ruiningyour oh so holy page
Old May 13, 2016 | 07:42 PM
TheShodan's Avatar
Moderator
Doesn't seem turbocharger related. Seems more like the cylinder head is at issue more than the turbocharger.
We understand the theft argument quite easily... But for the sake of simplicity, please Just take the plate off for the shot or use an editing tool next time. We'll be more professional towards you, if you are more professional with us.
Lawbags
Oct 9, 2017 03:37 PM
beamer
Jul 29, 2015 03:21 PM
momsgottagun
Oct 1, 2011 07:00 PM
anothersickhatch
Mar 25, 2004 08:47 PM
ItzTw
Dec 16, 2003 09:15 PM
