PTE 6466
Anyone running the PTE 6466? Thinking about trying this turbo out next season but I would like to hear some reviews since its still somewhat new and I couldnt find much info. on it.
Looking for some dyno graphs, videos, etc.. and yes I have already seen the one miller posted..
6266 vs 6466 vs 6766..its on a 2JZ but gives you an ideas
https://honda-tech.com/forums/drag-racing-36/precision-6266-vs-6466-vs-6766-dyno-graphs-inside-3042214/
Did you try here? http://bit.ly/Q9nETJ
Dyno plots on another motor are ******* pointless... I hate when people do that ****.
Ive looked, and not found much related to Hondas. The one or 2 IVe seen. looked alot lazier than I expected. Like to see one on a H or K motor.
In for info as Im shopping, and would consider one...
I look forward seriously to seeing how it works out for you...
DO you have any idea how hard youre going to push it?
What fuel
PSI?
Power "goal" etc..
Im interested
What fuel
PSI?
Power "goal" etc..
Im interested
I will be running C16 race gas, and as much PSI as it takes to get me to that 720 mark again. (I will end up buying a surge kit sometime next year)
I just HOPE this turbo isnt THAT laggy. I know my BB 6265 sure was. Heard the 6466 will spool about the same with alot higher whp rating.
I have a friend that had a 6265 on an H... HE hated it, said it was laggy... (Coming from a T04ZR like mine, 67 MM) another that came from a GT30R then a 3582R on a H with one, its laggy and lazy too... First guy put a 6766 on his motor and its like a lightswitch again compared to the 6265... Makes no sense, but hes right.
Pretty sure guy number 2 is going with a 6766 as well now
Im gong bigger, DOnt think Ill stop at the 6466, but am interested... Im thinking 6768 or a buddy has a brand new S372 with the race cover I can get for DIRTTTTT...
Not TO hard because im still on stock fuel lines so it will run out of fuel at the 720ish mark. The 6262 WOUlD work fine with my setup but I don't like running a turbo almost maxed out. Just asking for disaster IMO.
The 6262 i have on my car does great, made 690whp and could make a little more if i push it. I understand what you say about not pushing the turbo, but when they say stock fuel lines max out at 720ish is that with the AFR's @ 11.5 or are the AFR's 13.0? I know we made 757whp on stock lines a few years ago in my friends car but it was a 12.7-13.0 all across the board. It was on Q16 tho and it liked to be in that area. Not sure if C16 likes it that lean.
The 66 turbine wheel they have is the cool new ****. I keep hearing that the 6266 spools quicker than the old 6262 but i haven't seen it yet. I think they mean it spools quicker than the 6265 which spools like poo like Spiker said. I'd be surprised if it truly spools quicker than the 6262.
When I say max out I mean anymore PSI it wont hold anymore power it will just start to lean out. Not 100% sure of the AFR's as I didnt dyno the car.
highroller54
Sep 29, 2010 01:34 PM
