PT-67
Old Sep 13, 2003 | 08:35 AM
JDM92CX's Avatar
Default PT-67
I just got my Full-Race kit in the mail from Geoff and I must say the kit is well put together. I didn't speak the whole time I was opening the box. (lol) Does anyone here have experience with this turbo. I have this turbo but with a T3 housing instead of the T4 cause I'm boosting it on a stock B16 for right now. It also has a stage 5 wheel and T04S compessor housing with .70 compressor side and .63 hot side. Let me know your thoughts on this turbo
P.S. Thank's to Geoff...
Old Sep 13, 2003 | 08:39 AM
prelude beast's Avatar
Default Re: PT-67 (JDM92CX)
if it is made by full race i think boostedfed have full race pt67 from them except it is a t4 version.
Old Sep 13, 2003 | 09:00 AM
JDM92CX's Avatar
Default Re: PT-67 (jerseykid609)
I'm gonna see if I can get it to be tuned to 14psi on the stock motor with the hondata. With good tuning I think it can be done well. But it doesn't really have to strain on this motor. You would be surprised if it starts spooling low end
Old Sep 13, 2003 | 06:44 PM
JDM92CX's Avatar
For right now I have the valve train to take the revs up a little more. But I'm just concerned on the rings taking it
Old Sep 13, 2003 | 06:52 PM
boosted hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerseykid609 &raquo;</TD></TR><TR><TD CLASS="quote">a turbo that size will wake up over 15psi the stock motor is gonna strain to get it going but once it does oman the power !</TD></TR></TABLE>
I am making 312whp and 220tq at 8psi and 355whp and 240 tq at 11psi. I would say that the turbo has an incredible efficiency band.
Old Sep 13, 2003 | 06:59 PM
JDM92CX's Avatar
Default Re: PT-67 (boosted hybrid)
Wow that's really some badd azz power your making at low boost. Tell me a little about your setup and what computer your running. I knew this turbo would be good for low boost too
Old Sep 13, 2003 | 07:08 PM
1995 Civic Hatchback CX
Mods: Stock GSR block, 3mm head gasket, ARP headstuds, Edlebrock IM, Full Race manifold, 3" dp., 3" Thermal Exhaust, PWR Intercooler, Tial 40mm wg and bov, Full Race T3/T-Series turbo, 720cc injectors, Warlboro 255lph fuel pump, and Hondata S100.
BTW, your going to be terribly disappointed with your spool time with a stock bore b16a. The turbo is fairly laggy on a 1.8 displacement.
Old Sep 13, 2003 | 08:19 PM
JDM92CX's Avatar
I'm thinking it's gonna be pretty laggy on the b16 from the get go but I'll survive. hehe What FPR are you using
Old Sep 13, 2003 | 08:23 PM
Stock fpr, lines, fittings, ignition, block and head.
Old Sep 13, 2003 | 08:48 PM
Arturbo's Avatar
Better than steak
25 Year Member
That is laggy. I think on a 2.0L might help some.
Good numbers.
art
Old Sep 13, 2003 | 08:50 PM
Boostfed's Avatar
New User
Yeah I have that turbo but in the T4 version .68 A/R P trim turbine wheel.
B16A 84mm 10.2:1 CR, Full Race mani, 3" dp, Full Race T67
26psi and 28psi, the motor popped a headgasket which I am changing out now. I am making a couple mods for no more blown gaskets
I had made posts before about my spool times
"At 5500=8psi, 6000=15psi, 6500=23psi, 6750=27psi so alittle better, especially if I had a WORKING Electronic Boost Controller with some GAIN control, this was done on a Turbo XS standard Manual Boost controller, not even their ball and spring MBC"
Modified by Boostfed at 1:01 AM 9/14/2003
Old Sep 13, 2003 | 08:58 PM
rOby's Avatar
Default Re: PT-67 (Boostfed)
i wouldnt do it if i was you.
Old Sep 13, 2003 | 09:01 PM
Boostfed's Avatar
New User
Default Re: PT-67 (rOby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rOby &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt do it if i was you. </TD></TR></TABLE>
Wouldn't do what?
Old Sep 13, 2003 | 09:15 PM
Arturbo's Avatar
Better than steak
25 Year Member
The T4 works great, its the T3 I am worried about.
Old Sep 13, 2003 | 09:55 PM
rOby's Avatar
sorry terry, i didnt mean to qoute ur post.
i meant that i wouldnt put this turbo on a daily driver 1.6 uless you really appreciated the quiet period of lag before boost.
Old Sep 14, 2003 | 07:51 AM
JDM92CX's Avatar
Default Re: PT-67 (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">The T4 works great, its the T3 I am worried about.</TD></TR></TABLE>
Why are worried about the T3? I figured it would have full boost around say 5500-6000 and still have 3-4 rpms to play with
Old Sep 14, 2003 | 11:52 AM
slowsi00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">1995 Civic Hatchback CX
&lt;stock bore b16
9:1 comp
sc61
5200 rpms spool
full boost t like 5500-5600
redline at 8700.
at 12 psi 306whp
Old Sep 14, 2003 | 12:18 PM
Default Re: PT-67 (slowsi00)
Still isnt compariable to the t67 trim, its a much larger compressor trim. Also what is your turbine blade 76 or 79mm wheel?
Old Sep 14, 2003 | 12:22 PM
slowsi00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Still isnt compariable to the t67 trim, its a much larger compressor trim. Also what is your turbine blade 76 or 79mm wheel?</TD></TR></TABLE>
oh i know i was agreeing with you.
that is just way to much turbo for a stock b16
my car feels laggy, but i like the powa!
i dunno about the wheel size, i know that its a smaller sc61 if that helps any.
Old Sep 14, 2003 | 12:48 PM
Full-Race Geoff's Avatar
what are you worried about?? that it will make too much power
Old Sep 14, 2003 | 02:00 PM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I have that turbo but in the T4 version .68 A/R P trim turbine wheel.
Modified by Boostfed at 1:01 AM 9/14/2003</TD></TR></TABLE>
whats the displacement of 84mm b16a ?
Old Sep 14, 2003 | 02:31 PM
slowsi00's Avatar
Default Re: PT-67 (FFgeoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FFgeoff &raquo;</TD></TR><TR><TD CLASS="quote">what are you worried about?? that it will make too much power </TD></TR></TABLE>
to much powa is never a bad thing.
Old Sep 14, 2003 | 04:11 PM
Boostfed's Avatar
New User
Default Re: PT-67 (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">
whats the displacement of 84mm b16a ?</TD></TR></TABLE>
1.71 liter
Old Sep 14, 2003 | 05:36 PM
SpdFrk's Avatar
Will a 84.5mm bore equal or come close to 1.8l on a b16??
Old Sep 14, 2003 | 05:38 PM
TurboJesse
Guest
Posts: n/a
Default Re: PT-67 (SpdFrk)
no...1.76L i believe
