psi drop???????
Old Jul 29, 2005 | 08:21 AM
desiromeo812's Avatar
Default psi drop???????
so we went out tune my car last nite after th installation of my greddy kit. everything on the kit is fine . turbo is from a si kit. what i noticed was that the little thing on the wastegate where you connect the hose is a lil cracked. meanin jus the nipple thing rattles but its stil inside the waste gate.. also my exhaust manifold one of the corner bolts snapped off so there was somewhat a exhaust leak... we did a couple of WOT pulls and boost would hit about 9-10 psi .... later in the night boost would hit 9 at about 4900 RPM but would drop off to 5 right before my vtc kicked in at about 5500..... what could it be? i checked my charge pipes and no leakes.. could the waste gate be causing this? or is it the exhaust leak? or do i have a bigger problem....oh and btw it holds fool boost if i keep it at partial throttle all the way up to redline.
thanks in advance... sorry its so long
Old Jul 29, 2005 | 01:29 PM
Default Re: psi drop??????? (desiromeo812)
somebody?????/ anybody
Old Jul 29, 2005 | 01:35 PM
T3T495GSR's Avatar
change your oil
Old Jul 29, 2005 | 02:41 PM
DarknessJ's Avatar
I was told myself by a tuner that its just the internal wastegate by greddy. I took my car on the dyno to tune and i saw that myself too.
Old Jul 30, 2005 | 03:07 PM
Default Re: psi drop??????? (DarknessJ)
anyone else?
Old Jul 31, 2005 | 06:32 PM
DarknessJ's Avatar
i've also heard that the wastegate vacuum source could be routed to the bov, fpr or intake manifold to hold the boost up top...
Old Jul 31, 2005 | 10:46 PM
anyone else?
civic_jdm
May 24, 2005 02:17 PM
whackassfawker
Aug 11, 2004 07:27 PM
soulrider4ever
Apr 30, 2004 10:49 AM
Kevin
Nov 18, 2002 10:05 AM
slwazgsr
Sep 10, 2002 01:04 PM
