Project Big Block Update....
Old Jun 27, 2004 | 09:18 PM
  #26
RyanEJ8's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
Is that the retaining clip that's supposed to be on the axle?
-PHiZ</TD></TR></TABLE>
Why do I see two of them in there though?
I don't think its the retaining clip.
Old Jun 28, 2004 | 05:01 AM
  #27
EE_Chris's Avatar
Default Re: (PHiZ)
Looks like the spring that is part of the seal itself.
Old Jun 28, 2004 | 05:16 AM
  #28
ladysman's Avatar
Default Re: (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the spring that is part of the seal itself.</TD></TR></TABLE>
Yes it did.
Phiz, I will check it out on Thursday. I thought the same thing.
Ryan, it is a reman from Advance Auto. This is the 2nd one I have bought. The first one I bought for my EX Sedan daily driver was fine. This one had all sorts of problems. They swapped it our for a new one!! Another problem that should be solved. Also, when changing alternators I have to take the driveshaft out now cause the DSS axles are to honking big!! What a pain!!
Old Jun 28, 2004 | 05:21 AM
  #29
JDMCRX's Avatar
How are u installing the seal cause if u hit the seal the wrong way the spring will come out with out u knowing and its useless.
Also are u putting any lub on the seal before u put them in?
Old Jun 28, 2004 | 05:23 AM
  #30
ladysman's Avatar
Default Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">How are u installing the seal cause if u hit the seal the wrong way the spring will come out with out u knowing and its useless.
Also are u putting any lub on the seal before u put them in?</TD></TR></TABLE>
Which seal you talking about? I got 2 problems.
Old Jun 28, 2004 | 05:51 AM
  #31
PHiZ's Avatar
Default Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
Which seal you talking about? I got 2 problems. </TD></TR></TABLE>
I feel bad for you, son.
-PHiZ
Old Jun 28, 2004 | 05:53 AM
  #32
ladysman's Avatar
Default Re: (PHiZ)
That helps a lot. Both seals have springs (Cam and driveshaft seal). Tranny one came out. Cam one didn't. I must have missed something.
Old Jun 28, 2004 | 07:38 AM
  #33
RyanEJ8's Avatar
Yes it did.
Ryan, it is a reman from Advance Auto. This is the 2nd one I have bought. The first one I bought for my EX Sedan daily driver was fine. This one had all sorts of problems. They swapped it our for a new one!! Another problem that should be solved. Also, when changing alternators I have to take the driveshaft out now cause the DSS axles are to honking big!! What a pain!!</TD></TR></TABLE>
That sucks. That turns a 5 minute job into a 1 hour job.
Old Jun 28, 2004 | 08:38 AM
  #34
JDMCRX's Avatar
Default Re: (RyanCivic2000)
**** what company are the seals from A there old which i dout B there jobber POS.
The one thats cracked looks eiher u got a burr on ur crank or camshaft or it was ripped before u installed it
Order a set from honda put some grease in the center and on the cam and crank then in stal them themm the seal and the casing are flush make sure the seal sits straight them wipe acces grease off.
Never had a seal leak on me yet
Old Jun 28, 2004 | 09:52 AM
  #35
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">**** what company are the seals from A there old which i dout B there jobber POS.
Never had a seal leak on me yet</TD></TR></TABLE>
The ripped one is the cam seal. When it was installed, the engine was still out of the car and the rocker assembly wasn't even installed yet. In other words, the seal was installed on the cam then the cam in the head and then rocker assembly. Maybe this wasn't the best way to do it.
This time it will be pressed in with a socket. This what everyone else uses? I assume no Hondabond as the Helms mentions nothing about this. All it says it to wipe off the cam and housing, oil the cam and seal and press in.
Old Jun 28, 2004 | 12:21 PM
  #36
JDMCRX's Avatar
This time it will be pressed in with a socket. This what everyone else uses? I assume no Hondabond as the Helms mentions nothing about this. All it says it to wipe off the cam and housing, oil the cam and seal and press in.</TD></TR></TABLE>
Oh thats a mistake everytime i install the cam and the cam seal as one they leak
Old Jun 28, 2004 | 12:57 PM
  #37
Sonny's Avatar
Glad you found the problems, man.
Sonny
shawnlee250
Honda Civic (2001 - 2005)
Nov 2, 2011 01:30 PM
Honda_Accord
Sep 17, 2007 01:22 AM
cilvia
Feb 6, 2007 05:20 AM
X2BOARD
Oct 7, 2004 12:52 PM
diluted
Jan 17, 2004 07:54 PM
