Programing AT29C256 with pocket programer
Old Jun 7, 2004 | 10:58 AM
Sketch_hs's Avatar
Default Programing AT29C256 with pocket programer
The AT29C256 flash programable chip is not an option in the menu, can i use the 27c256 option to program it?
Anyone know?
Anyone have the newer software versions for it? it was bought over a year ago and now they want me to pay for new software?
Old Jun 7, 2004 | 12:41 PM
tthame1's Avatar
Default Re: Programing AT29C256 with pocket programer (Sketch_hs)
I have V1.72 and it has AT29C256 as an option
Old Jun 7, 2004 | 01:11 PM
Sketch_hs's Avatar
Default Re: Programing AT29C256 with pocket programer (tthame1)
can i get the software update from you? with password?
rodds@earthlink.net
thanks!
Old Jun 7, 2004 | 01:16 PM
tthame1's Avatar
Let me see if I can find it
Old Jun 7, 2004 | 07:04 PM
Sketch_hs's Avatar
well?
Old Jun 7, 2004 | 10:32 PM
Jaker's Avatar
You cannot use the 27C256 as the option for programming, as the programmer erases the 29C256 as it is programming. It won't do that if you select the 27C256. What version of software do you have? I have Ver. 1.42 from 25 Mar 2002, and its there.
Old Jun 8, 2004 | 01:29 PM
Sketch_hs's Avatar
Default Re: Programing AT29C256 with pocket programer (Jaker)
i had to open the FILEPROM.exe
now i have the option but i can't seem to get the programer to work
where is the erase option??
Old Jun 8, 2004 | 03:02 PM
Sketch_hs's Avatar
and i can't seem to change it from 5v to 12.5 WTF?
Old Jun 8, 2004 | 03:24 PM
Jaker's Avatar
It would help us to help you if we knew what version of the software you were using.
Old Jun 8, 2004 | 07:53 PM
Sketch_hs's Avatar
how can i check what version?
Old Jun 8, 2004 | 08:05 PM
Jaker's Avatar
When you open the program, the version is right at the top of the page, to the right.
Old Jun 8, 2004 | 08:20 PM
Sketch_hs's Avatar
3.49 Is what is says when i open up fileprom...
still can't program
I need to be a 12.5volts not 5volts right?
Old Jun 8, 2004 | 11:30 PM
Sketch_hs's Avatar
ne1?
Old Jun 9, 2004 | 08:44 AM
Sketch_hs's Avatar
Old Jun 10, 2004 | 07:39 AM
Sketch_hs's Avatar
Default Re: (Sketch_hs)
some one has to know
Old Jun 11, 2004 | 08:03 AM
Sketch_hs's Avatar
5 or 12?
i know some one knows!
Old Jun 11, 2004 | 09:09 AM
blumeany's Avatar
You need 5V with AT29C256.
Old Jun 11, 2004 | 07:20 PM
Sketch_hs's Avatar
Default Re: (blumeany)
okay, thats what it's set on.
But when i load the bin and go to flash it, it only goes for like 1/10 of a second and gives an error message, same thing w/ all 3 at29c256 i got. They are new so they should be good.
WTF
Old Jun 15, 2004 | 09:10 AM
Sketch_hs's Avatar
help me i want to start tuning!
27c256 burns fine, but i want to use the flash eprom!
what am i doing wrong?!
pauld
Apr 30, 2009 09:26 AM
gsr4door13
Jun 17, 2008 07:29 AM
wantboost
Welding / Fabrication
11
Mar 21, 2005 08:19 PM
