Profec B installation Help...
Old Jan 30, 2002 | 07:05 PM
td04civic's Avatar
Default Profec B installation Help...
This is a picture of my turbo, the td04H-15G from Greddy for the 92-95 civic ex. I wanted to know when installing the line from the control box to the wastegate do I "TEE" into the blue vaccum line or do I disconnect it and connect the boost controller vaccum line directly to the wastegate. If I do that what should I do with the other end of the blue vaccum hose thats connected to the turbo? If you could help it will be very helpful.
Thanks alot. Troy
Old Jan 30, 2002 | 07:09 PM
boost killz's Avatar
New User
Default Re: Profec B installation Help... (td04civic)
haha Dude again I will help you.... Take the hose off and use the port coming off the housing for your pressure source going to the "IN" portion of your solenoid and the "OUT" portion goes to the wastegate. TEE off the source from the back of the profec to our fpr vacuum.. Hope I said it clear enough this time. Peace,
If you don't believe me ask VTC_civic on the board. Thats how his AVC-R i hooked up but if you already tapped the charge pipe afer turbo just use that to go ino your "IN" portion and plug the ftting on the housing.
Nick
[Modified by boost killz, 11:11 PM 1/30/2002]
Old Jan 30, 2002 | 07:17 PM
td04civic's Avatar
Default Re: Profec B installation Help... (boost killz)
Thanks alot man...sorry to keep asking the same questions. Yep it was clear now.
Thanks.
Later
Troy
T25So
Jan 18, 2006 10:33 PM
asiankid29
Oct 10, 2004 12:14 PM
vtec-adykt
Sep 13, 2004 08:21 PM
VanHonda
Jun 8, 2003 04:01 AM
td04civic
Dec 27, 2001 01:34 PM
