Profec B
Old Dec 27, 2001 | 11:59 AM
td04civic's Avatar
Default Profec B
I'm installing the profec B on a 93 civic w/ the greddy turbo kit.
For the vaccum line leading to the wastegate do I "T" into the blue hose leading from the wastegate to the turbo or do i disconnect the hose and plug in the profec B line into the wastegate? Thanks for your help.
Old Dec 27, 2001 | 12:10 PM
boost killz's Avatar
New User
Default Re: Profec B (td04civic)
Ok I just basically learned alot from my experience with the install a few days ago.. In your case I know there is the pressure source coming from the bottom of the turbo's compressor for the civic kit( That should be an individual hose going to the "IN" portion of the solenoid of the black box, the "OUT" should have the hose connecting to the wastegate port. T off the hose from your fpr vaccum going to your source on the back of the Profec. And btw have the settings to low and have a buddy with you and slowly turn up the **** and find a good point for the mild to sharpen **** for quicker spool up but not so much that you will spike. Hope this helps,
Nick
Old Dec 27, 2001 | 01:34 PM
td04civic's Avatar
Default Re: Profec B (boost killz)
so would i have to "T" in the OUT line into the line that connects the wastegate to the turbo?
Thanks
b18_integra
Feb 18, 2008 04:42 PM
gdrum
Feb 16, 2004 10:21 PM
E-spec Tuner
Apr 10, 2003 09:54 AM
td04civic
Jan 30, 2002 07:17 PM
